Home > Off Topic > Log burner hints & tips
Page 2 of 3 <123>
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
[quote="Silver Back"]I seem to remember a similar thread on here about preparing a burning wood. It helpfully recommended this book:
https://www.amazon.co.uk/gp/product/085705...&psc=1
This is a great book, really brings out the scandi which is somewhere in us all!
Particularly interesting is the way they light fires, for years i always started from the base, bit of news paper kindling and stuff, wait for it to get going and then lay some logs coal jeatlogs whatever.
BUT they suggest stacking logs in neat rows two or three layers up on the grate and lighting a small fire on top, controversial i know!!!! Shocked Shocked
It does work, needs dry wood, which is a must, but essentially the cinders and embers drop through the gaps and ignites the fire then it gradually burns top/middle down.
I guess it probably stems from the desire to not have to work the fire too much ie its loaded and burns for hours.
Dry wood is a must, i like Beech or birch but im not fussy just depends on what i can get hold of. Also bring your logs in a day or two before hand, even if seasoned and under cover outside they will still be damp.
Post #931227 26th Nov 2021 10:09am
dorsetsmith
great for making kinder ling from logs
natural firelighter Lekto wood fuel
https://www.lektowoodfuels.co.uk/?gclid=Cj...HcQAvD_BwE
Post #931238 26th Nov 2021 10:44am
Snowy90
I like that good find
Post #931240 26th Nov 2021 10:53am
jst
SJM2018 wrote:
I've been googling the issue of smoke coming back into the room and a couple of people have suggest the "Scandinavian technique" of putting the kindling on top of the logs. Its meant to heat the flu quicker, so it starts to draw sooner.... I'll give it a go, but not convinced it will light the logs! Jst's approach makes more sense to me.
lay fire as normal and add extra newspaper or similar above light both.
or using your gas lamp, preheat some of the metal work top end of the stove/bottom of flue with gas then light kindling. we run 3 x 9kw fires so soon got a knack to it! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #931244 26th Nov 2021 11:07am
gilarion
This is a list of the
best and not so good wood to burn For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #931261 26th Nov 2021 12:30pm
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
I’ve managed to find a local supplier of well seasoned ash (local woodland cemetery believe it or not).
We’re getting a moisture meter to check it’s all suitably dry.
I’ve also ordered a Gränsfors Bruk hatchet for making kindling! 2011 CSW XS 90
Post #931364 26th Nov 2021 11:18pm
jst
Moisture meter? I wouldn't worry on that too much.
Next will be nice husky 346xp and a tractor powered log splitter! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #931377 27th Nov 2021 7:46am
Bluest
Bloody glad of ours this morning. Powers been off since the early hours due to Storm Arwen and it's freezing. I don't use it a lot but it has been a great back up for when there's power cuts over the years. 2007 110 TDCi Station Wagon XS
Post #931390 27th Nov 2021 10:07am
Buy a pair of welding gauntlets to help load the wood and place it exactly where you want. A pair of these and a good fireside tool set are my essentials.
Post #931398 27th Nov 2021 10:46am
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
... and my twp pence worth.
Had a new log burner fitted two years ago but initially the results were poor. The fire was not drawing too well after lighting and it was rather smokey.
The fault was the chimney was not high enough and the top of the roof was shading the chimney top when the wind was blowing in certain directions.
The fix was to add a metre of chimney - after that all was OK.
Log wise, as a norm we order kiln dried had woods but of late I've been installing some 500+ tanalised round fencing stakes and on average had to cut a foot off them. Those cut offs have been been great on the fire, burning quicker but still giving out plenty of heat and not smoking the glass.
Oh .. and keeping the glass clean ... we don't any chemicals, we simply use the burnt ash on a damp cloth or piece of kitchen roll.
HTH
John 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #931433 27th Nov 2021 4:02pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
When you are ready to up your wood game: https://www.hachette.co.uk/titles/lars-myt...782066620/ WARNING.
This post may contain sarcasm.
Post #931436 27th Nov 2021 4:35pm
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
Good book that, had my copy a few years now
Post #931500 27th Nov 2021 10:12pm
SJM2018
Here it is!
Struggling to maintain a consistent temperature, but sure I’ll get the hang of it soon.
I know storing combustibles next to it is a no no, but they’re not touching and the logs are only getting slightly warm (the sides and back appear to be well insulated). 2011 CSW XS 90
Post #931761 29th Nov 2021 9:06pm
Chopperone
How are you getting on with your Hunter?
We use to have one ( not the same as yours)- it was only useful as an anchor.
Zero control over heat , a pig to light & forever chucking wood on it.
Swapped it for a Clearview; best thing l ever did.
Hunters are just not airtight IMHO.
Guy May your life be like toilet paper ; long & useful.
Post #936377 4th Jan 2022 10:38pm
How are measuring that?
A magnetic stove thermometer like this will provide an easy indication
Post #936386 5th Jan 2022 6:41am
Page 2 of 3 <123>
