Home > Puma (Tdci) > Noise when turning
PatrickB
Noise when turning
Evening all, hopefully someone here might be able to offer some help on a noise my 110 has developed.
When turning, particularly on full lock, I get a whining sound.
I’ve uploaded a video to try and help:
https://youtube.com/shorts/WElsQ6AdwF8?feature=share
Thanks in advance for any help!
Patrick
Post #930618 21st Nov 2021 6:54pm
mustafasoleiman
United Kingdom 2003 Defender 90 Td5 XS CSW Indus Silver
low on fuel for the steering pump? http://instagram.com/h4vou/
Post #930624 21st Nov 2021 7:10pm
Co1
Have you got a steering damper? Try some lube on the seals if you have. Mine sounded the same and a bit of Teflon spray lube did the trick.
Post #930651 22nd Nov 2021 6:08am
PatrickB
Apologies for the slow response but thanks both for your replies.
I tried spraying some Teflon spray on the steering damper but that wasn’t the issue although I’m sure it did it some good!
Turned out that the power steering fluid was low. Topped it up and fixed the problem instantly. In case anyone comes across this in the future, this video explains where the reservoir is/looks like very clearly at 3mins10:
Post #932303 3rd Dec 2021 2:40pm
