Home > Td5 > 2000 td5 fuse box center |
MY 1999 to 2001 fuse and relay
driver seat box ( MY1999 rave ) working from foot well end first yellow relay cooling fan next one yellow relay compresses clutch A/C next one black relay Glow plugs next one black relay ABS return pump next one yellow relay ( main ) canter box fuse box ( MY1999 rave ) working from passenger side LH side looking from inside first yellow relay starter next yellow relay heated rear screen next yellow relay head lamp next brown relay sounder alarm ( Missing relay ) next green relay fuel pump also ecu delay windscreen wiper unit brown / relay hazed warning black Last edited by dorsetsmith on 15th Nov 2021 7:09pm. Edited 2 times in total |
15th Nov 2021 3:48pm |
Kai3747 Member Since: 16 Oct 2021 Location: Nicosia Posts: 12 |
Thanx dude. I am trying to install ashcrofts compushift and it writes on a set of cables (black and red this): "..break the black/orange signal wire (starter solenoid) from the loom coming from the fuse box under the right hand seat and wire in these wires from XY switch to complete the broken circuit.."
1st issue : under my drivers seat there is no cable in fuse box on starter with orange/black , and i found on bulkhead fuse box a cable orange/black but it does not have relay on it.( by the way car starts fine). How i proceed ?? Pictures for check |
15th Nov 2021 4:03pm |
Click image to enlarge Click image to enlarge wiring diagram for 2000 TD5 defender https://1drv.ms/b/s!AtZSoWFHDgnGlQeAGaPfIamVrwlG?e=fT42ew Click image to enlarge wires to the starter relay brown-white ----brown--red-------------- white---red---------------Black--orange electrical library for 2000 https://1drv.ms/b/s!AtZSoWFHDgnGlQl1EeE7_sPhZZim?e=MedKN7 Click image to enlarge Last edited by dorsetsmith on 15th Nov 2021 7:21pm. Edited 3 times in total |
15th Nov 2021 5:24pm |
Thanx mate, can you recognise for me the orange black cable where is in my harness? I am not so familiar;) is the cable in picture?:
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
15th Nov 2021 5:48pm |
