Home > Td5 > 2000 td5 fuse box center
Kai3747
Cyprus 2001 Defender 110 Td5 DCPU Auto Bonatti Grey
[i]Hi while i am trying to install the ashcrofts compushift i noticed that some relay are missing on my center dash console!My car is 2000 td5 mbs ecu. Is any one know what this relay does? (Car is working fine with out it)
Here are some pictures:
Post #929841 15th Nov 2021 3:02pm
dorsetsmith
MY 1999 to 2001 fuse and relay
driver seat box ( MY1999 rave )
working from foot well end
first yellow relay cooling fan
next one yellow relay compresses clutch A/C
next one black relay Glow plugs
next one black relay ABS return pump
next one yellow relay ( main )
canter box fuse box ( MY1999 rave )
working from passenger side LH side looking from inside
first yellow relay starter
next yellow relay heated rear screen
next yellow relay head lamp
next brown relay sounder alarm ( Missing relay )
next green relay fuel pump
also ecu delay windscreen wiper unit brown / relay hazed warning black
Post #929845 15th Nov 2021 3:48pm
Kai3747
Thanx dude. I am trying to install ashcrofts compushift and it writes on a set of cables (black and red this): "..break the black/orange signal wire (starter solenoid) from the loom coming from the fuse box under the right hand seat and wire in these wires from XY switch to complete the broken circuit.."
1st issue : under my drivers seat there is no cable in fuse box on starter with orange/black , and i found on bulkhead fuse box a cable orange/black but it does not have relay on it.( by the way car starts fine).
How i proceed ?? Pictures for check
Post #929847 15th Nov 2021 4:03pm
dorsetsmith
wiring diagram for 2000 TD5 defender
https://1drv.ms/b/s!AtZSoWFHDgnGlQeAGaPfIamVrwlG?e=fT42ew
wires to the starter relay brown-white ----brown--red-------------- white---red---------------Black--orange
electrical library for 2000
https://1drv.ms/b/s!AtZSoWFHDgnGlQl1EeE7_sPhZZim?e=MedKN7
Post #929862 15th Nov 2021 5:24pm
Kai3747
Thanx mate, can you recognise for me the orange black cable where is in my harness? I am not so familiar;) is the cable in picture?:
Post #929864 15th Nov 2021 5:48pm
