Home > Tdi > Permanet live - Simple for some - Not for me!
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
Hi folk
My newly fitted radio keeps dumping its setting and has become a PITA to keep re-setting.
I've now learned that the radio's memory needs a permanent power source ... so my radio is in the area above the cigarette lighter / rear wiper switch.
Can anyone please tell me where I can pick up a constant rather than switched live please.
MTIA
John 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #929639 13th Nov 2021 7:22pm
nitram17
Hazard light feed i think that's permanent live.
Post #929648 13th Nov 2021 9:00pm
Cubflyer
Thanks Nitram - Sounds a good starting place for tomorrow Smile
Post #929657 14th Nov 2021 12:02am
Dinnu
From your profile, I assume that you are referring to a 300tdi.
Although I never owned a 300, I would have assumed that you already have a permanent live behind the cigarette lighter cover.
My MY88 has it from the factory, and it is a base spec model. I think the colour coding did not change, so you should be looking for a purple wire. The courtesy light, also permanent live, as well as the supply for the hazard switch should be purple.
Edit: The interior light and the hazard light are on different fuses. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #929661 14th Nov 2021 3:05am
Dinnu
I managed to find the below schematic for a MY97.
The memory supply to the radio, permanent feed, the wire is purple and is through Fuse 2 (which is the same fuse as the interior light).
The switchable power supply, which is what you already have is through Fuse 7, and wire colour is white/red.
Ensure that you have both switching supply and permanent feed to the radio. This way the radio switches off when you switch off from the ignition key, but keep a very small amount to power to the radio for memory purpose.
Post #929662 14th Nov 2021 3:40am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
On my 300Tdi with a Pioneer radio I had the same problem and the solution was to just swap the 2 input wires around. Not sure where I got the informatiin from but the saved settings were not dumped. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #929671 14th Nov 2021 9:07am
Cubflyer
Morning Dinnu - Thank you very much for the two posts and diagram - much appreciated!
Hopefully that will sort my issue out, just got to wait for it to stop raining! Smile
ATB
Post #929673 14th Nov 2021 9:23am
Cubflyer
Thanks Jeffers - appreciate the information too.
Post #929674 14th Nov 2021 9:25am
Dinnu
Check the radio. But most will have a red and yellow wire.
Usually the red will connect to white/red on the landy and yellow connects to purple. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #929676 14th Nov 2021 10:23am
Cubflyer
Thank you very much to all who replied - GREATLY appreciated!
Purple wire found and connected to the yellow of the radio - all settings now being held in the memory Very Happy
... next job ... 2010 Defender 90 300Tdi CW (White/1994)
Post #929696 14th Nov 2021 1:26pm
