Home > Wheels & Tyres > DCPU - I need to extend the spare wheel retainer. Options?
m33ufo
Wales
I've recently changed the wheels on my DCPU. The new ones, Nakatanenga ANR Classic's, are wider with a zero offset so of course the bolt which retains the spare is no longer long enough. Can a longer version be purchased? Is there another option?
Thanks Thumbs Up
 110 DCPU
Mark
Post #926869 23rd Oct 2021 3:56pm
Stud connector and some threaded bar?
Post #926872 23rd Oct 2021 4:39pm
dorsetsmith
another option 10mm square metal bar to make a folk and can be made as long as needed
You can purchased a longer version but only for
Alloy wheels KTC500050
Post #926873 23rd Oct 2021 4:42pm
hank
Defender wheel nut is M16x1.5 so get yourself a length of M16x1.5 threaded rod cut to length, grind two flats on one end with a hole cross drilled to suit the bulkhead bracket and bob’s your uncle. Can use the original wheel nut to secure > 110 XS Double Cab
Post #926880 23rd Oct 2021 5:12pm
m33ufo
Wales
Thanks for the suggestions gents Thumbs Up 110 DCPU
Mark
Post #926882 23rd Oct 2021 5:19pm
