![]() | Home > Wheels & Tyres > DCPU - I need to extend the spare wheel retainer. Options? |
Stud connector and some threaded bar?
another option 10mm square metal bar to make a folk and can be made as long as needed
![]() Click image to enlarge You can purchased a longer version but only for Alloy wheels KTC500050 |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2320 ![]() ![]() ![]() |
Defender wheel nut is M16x1.5 so get yourself a length of M16x1.5 threaded rod cut to length, grind two flats on one end with a hole cross drilled to suit the bulkhead bracket and bob’s your uncle. Can use the original wheel nut to secure > 110 XS Double Cab
m33ufo Member Since: 19 Jan 2008 Location: Cardiff Posts: 1150 ![]() ![]() |
Thanks for the suggestions gents
![]() Mark |
