Home > Td5 > Td5 110 SW value? (needs new chassis)
Adammacky
Long story short...
Mot failure due to rotted chassis, new it was coming but didn't see it coming so soon!
Finances at the moment don't stretch to the galvanised route unfortunately...
So how much would it be worth?
I understand that defenders are only worth what someone is willing to pay but can people give me an idea so I can get closer to a decision.
1999 Td5 110 SW, 147k miles, 10+ owners
Decent panels and good interior, sound engine and gearbox but does need a new chassis, bulkhead not great either.
In an ideal world I'd keep it and have it put on a galvanised chassis and bulkhead, always been a dream car for me and loved every second of owning and driving it! But... I can't afford it right now!
So, how much might it be worth as it is?
Whats the rough cost to galvanize? (In a year or so)
What would you do?
Thanks in advance Thumbs Up
...sorry for the vagueness Laughing
Post #926294 18th Oct 2021 9:46pm
lightning
l would guess around £6,000 in the current market.
Probably £5,000 to fit a new chassis depending on what else needs doing, if it needs a bulkhead l expect that it will be more.
Good 110 TD5 SW are currently £15,000 so the figures add up if you decide to keep it.
Can you get it patched up for 12 months and then repair it properly next year? lf you sell, you will always regret it.
Post #926309 19th Oct 2021 7:07am
Matt110
...or as a different logic, it's perfectly stable and assuming you left it on a charger and started it occasionally won't deteriorate beyond the bits you're repairing anyway, park it for a year whilst you accrue funds, buy a cheap runabout for 18 months, then have it re-chassis'd? Probably the way I'd go. A vehicle you know is worth quite a bit.
Post #926312 19th Oct 2021 7:29am
Adammacky
Its already been patched up and welded to get this far, I will upload some pictures soon.
Post #926313 19th Oct 2021 7:35am
kenzle8a
New chassis and decent baulk head and + fittings and painting are probably going to run you towards 6k before labour. Thats not even accounting for mission creep. For a spares or repair I don't think I would be happy spending over 5k.
Post #926318 19th Oct 2021 8:08am
Adammacky
Here's the pictures...
Crazy what 12 months can do
Post #926323 19th Oct 2021 8:28am
kenzle8a
They rot from the inside which is why its easy to get a surprise.
Post #926327 19th Oct 2021 8:39am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I changed a chassis from a 90 ones. You will as I did, find a lot more that needs replacing.
I came to the conclusion that doing it yourself it takes 3 times as much time and 2 times as much money to do it then that you calculate before or the other way around if you buy a lot of parts instead of refurbishing them.
Restoring it yourself is fun but it is a real job. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #926340 19th Oct 2021 10:18am
lightning
That corrosion is scary, l've just ordered some more XCP rust blocker to spray inside my 2006 110's chassis!
lt's already got about five tins in each side.
Post #926388 19th Oct 2021 2:08pm
