Home > Td5 > Td5 110 SW value? (needs new chassis) |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2761 |
l would guess around £6,000 in the current market.
Probably £5,000 to fit a new chassis depending on what else needs doing, if it needs a bulkhead l expect that it will be more. Good 110 TD5 SW are currently £15,000 so the figures add up if you decide to keep it. Can you get it patched up for 12 months and then repair it properly next year? lf you sell, you will always regret it. |
19th Oct 2021 7:07am |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 680 |
...or as a different logic, it's perfectly stable and assuming you left it on a charger and started it occasionally won't deteriorate beyond the bits you're repairing anyway, park it for a year whilst you accrue funds, buy a cheap runabout for 18 months, then have it re-chassis'd? Probably the way I'd go. A vehicle you know is worth quite a bit.
19th Oct 2021 7:29am |
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 |
Its already been patched up and welded to get this far, I will upload some pictures soon.
19th Oct 2021 7:35am |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
New chassis and decent baulk head and + fittings and painting are probably going to run you towards 6k before labour. Thats not even accounting for mission creep. For a spares or repair I don't think I would be happy spending over 5k.
19th Oct 2021 8:08am |
Here's the pictures...
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Crazy what 12 months can do |
19th Oct 2021 8:28am |
They rot from the inside which is why its easy to get a surprise.
19th Oct 2021 8:39am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I changed a chassis from a 90 ones. You will as I did, find a lot more that needs replacing.
I came to the conclusion that doing it yourself it takes 3 times as much time and 2 times as much money to do it then that you calculate before or the other way around if you buy a lot of parts instead of refurbishing them. Restoring it yourself is fun but it is a real job. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
19th Oct 2021 10:18am |
That corrosion is scary, l've just ordered some more XCP rust blocker to spray inside my 2006 110's chassis!
lt's already got about five tins in each side. |
19th Oct 2021 2:08pm |
