Home > Puma (Tdci) > Demand Engineering exhaust fitment
Matt3932
Seeking advice on fitment of a Demand Engineering exhaust system for a 2.4 Puma.
Looking to buy the cat-shell downpipe & sport silencer combination. Are there any pitfalls to be wary of in fitting it?
I think I've read that removing the OEM cat & down-pipe can be a bit of a nightmare...?
Post #925916 16th Oct 2021 10:59am
Merlin
I have one fitted onto my 110, 2.4L one.
I have the exhaust pointing out of the side for a number of reasons and find it a wonderful system so well made. BTW when lifting off there is a howl like a owl and I love it!
Peter
Post #925940 16th Oct 2021 2:14pm
Matt3932
Any issues with fitting the system?
Post #925945 16th Oct 2021 3:22pm
Co1
It is very straight forward. The most difficult bit is the rubber hangers!
Post #925976 16th Oct 2021 6:47pm
kenzle8a
Mr sheen on rubber hangers is a great trick to guide on and off
Post #925997 16th Oct 2021 9:16pm
Matt3932
If I ever own a pub, I'm going to call it "The Howling Owl" Laughing
Mr Sheen on rubber hangers - noted
Thank you both very much! Will get it ordered
Post #926033 17th Oct 2021 9:07am
freddie206
United Kingdom 2006 Defender 110 Td5 HT Belize Green
Can’t speak to the 2.4 version but I bought their 110 Td5 version.
Fantastic quality exhaust and excellent customer service. I called to place an order, they welded up a down pipe with cat shell and posted it the same day.
And to top it off it makes a pretty decent noise under acceleration without being too outrageous on idle.
Post #926043 17th Oct 2021 11:01am
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
I have a 2.4 version on order with them having done a load of research. Looking forward to getting it .. hopefully before the MOT Embarassed
I’d been ‘getting my money’s worth’ out of the original and it’s now way past its best.
Post #926053 17th Oct 2021 12:45pm
bear100
Done mine on the drive, the old cat was tricky to get out but not that bad, the new went in very easily, top tip is to leave the flange bolts loose until you have it all in place
👍 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #926063 17th Oct 2021 2:25pm
Matt3932
great, thank you
Post #926064 17th Oct 2021 2:33pm
Tonser
I'll be installing my Demand back pipe this week. Quick question ... I'll be doing it on the drive as no access to ramps unfortunately. Is there enough wriggle room to get the new pipe in with it on an axle stands and the wheel off ?
Thanks
Tony
Post #959592 26th Jul 2022 4:36pm
Harry.O
I had no problem installing mine with just a wheel off Thumbs Up 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #959603 26th Jul 2022 5:15pm
Tonser
Thats great to know thanks Harry Thumbs Up
Post #959613 26th Jul 2022 6:29pm
Ianh
One issue you may find is getting the old rear section off over the axle. If so jack and put a stand under the chassis, that way the axle will drop sufficiently to get the old rear section out.
Ky jelly works on the hangers as well, and then washes away in the rain.
Post #959620 26th Jul 2022 7:32pm
Alternatively a 9" angle-grinder will make getting the rear section off a breeze! Mr. Green
Post #959623 26th Jul 2022 7:52pm
