Home > Technical > Puma Rear door hinge question
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
Truck is in the shop so I’m planning stages here
Concerning the rear door lower most hinge. Two long bolts go through the door and are bolted that way. But how do I access the two bolts that hold the lowest most door hinge to the tub? Iirc it’s below the wheel arch level so I’d not know where the nuts are. One is lose and I’ll swap to stainless while I’m there too. Thanks
Post #923989 1st Oct 2021 11:17pm
Oldowner
Put your hand behind the plastic mudflap on the inside of the rear wheelarch.
Post #923995 2nd Oct 2021 6:00am
big110
Thx for that mate
Post #924057 2nd Oct 2021 1:22pm
