Puma Rear door hinge question
Truck is in the shop so I’m planning stages here
Concerning the rear door lower most hinge. Two long bolts go through the door and are bolted that way. But how do I access the two bolts that hold the lowest most door hinge to the tub? Iirc it’s below the wheel arch level so I’d not know where the nuts are. One is lose and I’ll swap to stainless while I’m there too. Thanks
2nd Oct 2021 12:17am
Oldowner
Put your hand behind the plastic mudflap on the inside of the rear wheelarch.
2nd Oct 2021 7:00am
big110
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
