Home > Technical > Side indicator repeater - td5 |
check and make shore earth and indicator + voltage the Side indicator repeater plug
24th Sep 2021 4:11pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5695 |
Is it connected to the correct wires? I once had some body work done and when they reassembled it they found the wrong, but fittable connector in the wing and used that. Simple swap after working out.
Worth a check. |
25th Sep 2021 6:20am |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 910 |
Funny you should say that. I was rummaging around in the wing whilst remaking connectors for the other lights and found an identical connector. I tried fitting that to the indicator and hey presto, it worked.
All sorted now, thanks for the suggestions. Next job is to fathom out the imperative NS side lights and number plate light. |
25th Sep 2021 6:39am |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 |
On my 110 there was a cable that was broken, first I rewired ir from the front one, but then I found it broken when I removed the wheel "eyebrow" Augusto
Defender 110 TD5 2001 Discovery 4 TDV6 |
25th Sep 2021 7:58pm |
