Home > Technical > Side indicator repeater - td5
bodstruck
On the off chance I am missing something simple...
The offside indicator repeater on my 05 110 td5 does not work. All the other indicators are fine as is the N/S repeater. It i snot the light itself as I have swapped them over to test.
All fuses are OK and wiring, as far as I can trace it, seems to be OK.
Any suggestions?
If all else fails I will see if I can re-wire it by connecting to the main indicator on that side.
Thanks
Post #922626 24th Sep 2021 1:48pm
dorsetsmith
check and make shore earth and indicator + voltage the Side indicator repeater plug
Post #922658 24th Sep 2021 4:11pm
landy andy
Is it connected to the correct wires? I once had some body work done and when they reassembled it they found the wrong, but fittable connector in the wing and used that. Simple swap after working out.
Worth a check.
Post #922706 25th Sep 2021 6:20am
bodstruck
Funny you should say that. I was rummaging around in the wing whilst remaking connectors for the other lights and found an identical connector. I tried fitting that to the indicator and hey presto, it worked.
All sorted now, thanks for the suggestions.
Next job is to fathom out the imperative NS side lights and number plate light.
Post #922709 25th Sep 2021 6:39am
ajps72
2001 Defender 110 Td5 SW Chawton White
Re: Side indicator repeater - td5
On my 110 there was a cable that was broken, first I rewired ir from the front one, but then I found it broken when I removed the wheel "eyebrow" Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #922797 25th Sep 2021 7:58pm
