Home > Puma (Tdci) > Should I clean engine ??
Bundubasher
South Africa 2007 Defender 110 Puma 2.4 SW Chawton White
Just returned from northern Mozambique. Had to a lot of driving through mud an rivers etc. The engine compartment has a lot mud everywhere. Must I clean the engine? Should I leave the sand and mud in case I damage the electrics etc?
Thanks
Anthony
Post #6233 12th Jan 2009 6:12pm
diffbeer
Clean it . Spray electrical areas with WD40 and leave to dry .Nothing like mud etc left there to initiate corrosion and acting as a grinding paste to all moving parts.
Post #7001 7th Feb 2009 1:38pm
fekete
Same as above WD40 jetwash get rid,
Iv had no problems Thumbs Up
leve it running NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #7003 7th Feb 2009 2:00pm
jst
i would steam clean it yes. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #7010 8th Feb 2009 12:17pm
Laurie
Do it with a warmed up engine so it dries out rapidly.
Post #7011 8th Feb 2009 12:23pm
jst
and go for a drive straight after. (good practice after cleaning any vehicle)
i have always steam cleaned or pressure washed engines either off or running tdi, tgv, td5 - tdci hasn't been used properly yet so is yet to be done. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #7013 8th Feb 2009 12:48pm
Bundubasher
Thank you everyone for the advice. I was a bit worried about those electrical connecting plugs around the engine. I will buy some WD40 and spry it on the electrical connecting plugs etc. And then spray the engine with carefully with water.
Regards
Anthony
Post #7041 9th Feb 2009 8:59am
alantd
WD40 - never leave home without it Thumbs Up One that started out as a 2.4 TDCi 110 XS
Post #7050 9th Feb 2009 12:44pm
Laurie
On special at Lidl next Monday Very Happy
Post #7052 9th Feb 2009 1:40pm
fekete
Also excellent for removing oil off things and
driveways Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #7053 9th Feb 2009 2:06pm
diffbeer
If you dont have WD40 in SAFFA , use Q20 ,spray all connectors , pressure wash , and drive it dry
Post #7127 10th Feb 2009 10:21pm
