Home > Puma (Tdci) > Should I clean engine ?? |
diffbeer Member Since: 18 Nov 2008 Location: Farnborough Posts: 44 |
Clean it . Spray electrical areas with WD40 and leave to dry .Nothing like mud etc left there to initiate corrosion and acting as a grinding paste to all moving parts.
7th Feb 2009 1:38pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Same as above WD40 jetwash get rid,
Iv had no problems leve it running NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY Last edited by fekete on 8th Feb 2009 12:25pm. Edited 1 time in total |
7th Feb 2009 2:00pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8096 |
i would steam clean it yes. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
8th Feb 2009 12:17pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Do it with a warmed up engine so it dries out rapidly.
8th Feb 2009 12:23pm |
and go for a drive straight after. (good practice after cleaning any vehicle)
i have always steam cleaned or pressure washed engines either off or running tdi, tgv, td5 - tdci hasn't been used properly yet so is yet to be done. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
8th Feb 2009 12:48pm |
Bundubasher Member Since: 25 Sep 2008 Location: Sandton Posts: 34 |
Thank you everyone for the advice. I was a bit worried about those electrical connecting plugs around the engine. I will buy some WD40 and spry it on the electrical connecting plugs etc. And then spray the engine with carefully with water.
Regards Anthony |
9th Feb 2009 8:59am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
WD40 - never leave home without it One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
9th Feb 2009 12:44pm |
On special at Lidl next Monday |
9th Feb 2009 1:40pm |
Also excellent for removing oil off things and driveways NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
9th Feb 2009 2:06pm |
If you dont have WD40 in SAFFA , use Q20 ,spray all connectors , pressure wash , and drive it dry
10th Feb 2009 10:21pm |
