Home > Technical > Defender keeps locking itself!
Titan133
United Kingdom 2004 Defender 110 Td5 CSW Bronze Green
I have a 2004 110 XS with central locking. It insists on locking itself the moment the doors shut, which is very annoying if the door blows shut during the daily farm gate routine. It’s even more annoying if the engine’s running and I forget to open the window before jumping out!
Is there any way to disable this self-locking feature?
Thanks ——————————
2004 110 TD5
Post #919009 28th Aug 2021 4:18pm
dorsetsmith
you have PM
Post #919015 28th Aug 2021 4:43pm
dorsetsmith
best way to read the set up from the AS-10
Post #919027 28th Aug 2021 6:02pm
landy andy
If it hasn’t always done this then I would assume something has altered in the drivers door lock mechanism as that is the door that activates the CL
Post #919028 28th Aug 2021 6:17pm
Titan133
Thanks for the replies. I think I need to read that 10-AS alarm guide and see what I can change. ——————————
2004 110 TD5
Post #919044 28th Aug 2021 10:07pm
rtm89
United Kingdom 2010 Defender 110 Puma 2.4 USW Galway Green
Mine did it whilst running in the yard. Turned it on to defrost shut the door and click, all the locks dropped.
Worst thing was my spare key was at work Banging Head
Think it ended up being water ingress that had caused it. I looked at bit suspect driving to work with the rear quarterlight window missing!
Post #919069 29th Aug 2021 9:36am
Titan133
I’m going to have a look inside the door and see if the mechanism is corroded or something. It could affect the central locking I reckon. The other problem I have with the drivers door is the plastic lock/unlock knob has snapped and is useless. Hopefully I can get a spare. ——————————
2004 110 TD5
Post #919093 29th Aug 2021 2:49pm
