Home > Technical > Defender keeps locking itself! |
you have PM
28th Aug 2021 4:43pm |
best way to read the set up from the AS-10
28th Aug 2021 6:02pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5755 |
If it hasn’t always done this then I would assume something has altered in the drivers door lock mechanism as that is the door that activates the CL
28th Aug 2021 6:17pm |
Titan133 Member Since: 30 Dec 2016 Location: Dorset Posts: 46 |
Thanks for the replies. I think I need to read that 10-AS alarm guide and see what I can change. ——————————
2004 110 TD5 |
28th Aug 2021 10:07pm |
rtm89 Member Since: 14 May 2013 Location: North Yorkshire Posts: 256 |
Mine did it whilst running in the yard. Turned it on to defrost shut the door and click, all the locks dropped.
Worst thing was my spare key was at work Think it ended up being water ingress that had caused it. I looked at bit suspect driving to work with the rear quarterlight window missing! |
29th Aug 2021 9:36am |
I’m going to have a look inside the door and see if the mechanism is corroded or something. It could affect the central locking I reckon. The other problem I have with the drivers door is the plastic lock/unlock knob has snapped and is useless. Hopefully I can get a spare. ——————————
2004 110 TD5 |
29th Aug 2021 2:49pm |
