Home > Maintenance & Modifications > Britpart spare wheel carrier rattle.
pilsburypie
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
I went for the cheaper option. Seen great reviews of the ORE carrier but had limited cash and went Britpart.
Yep, I know….. but it’s done now. Bloody thing rattles. Basically there’s a nylon cylinder that slides in and out of a tube as the door opens and closes. This is fractionally small which therefore allows a bit of play causing the rattle. I can put my hand on the spare wheel and pull it back and forth 1mm and recreate.
Any tips on bulking out the nylon cylinder fractionally? This rattle is blowing my mind.
No need to advise me against going cheapest. I’ve learned that lesson.
Post #918585 24th Aug 2021 9:39pm
I have the same carrier and generally find it to be a good bit of kit. I'd check to make sure that the nut on the end of the threaded rod into that cylinder is tight as the first port of call. The instructions for that arrangement aren't particularly great and it's possible to assemble it in such a way that it shakes itself loose almost immediately, which results in the rattling that you've described. I ended up changing the nut/washer arrangement and including a nyloc, which cured it for me.
There's some more detail in my build thread starting here and the following few posts:
https://www.defender2.net/forum/post833606.html#833606 Darren
Post #918592 24th Aug 2021 9:59pm
pilsburypie
Great thread and advice. I’ll look into that.
Post #918603 24th Aug 2021 10:42pm
natyeo
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
Another little mod worth doing with them drill out and tap / fit grease nipples to feed hinge bolthttps://www.defender2.net/gallery/albu...1%2529.jpg 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility
1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going
1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms
1971 Series 3 88, Perkins 4203,M8000,SATs,O/D,
Post #918611 24th Aug 2021 11:12pm
pilsburypie
Rattle fixed. It’s a Censored to tighten the nuts against each other. When tightening up the outside one, it just seems to want to undo the thread on that nylon piston thingy.
Done up fairly tight with a nylock nut and seems to be rattle free. Just disappointed I couldn’t crank it a bit more
Thanks for the advice.
Post #919958 4th Sep 2021 4:30pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I used a set of mole grips to hold the plastic piston and fitted spring washers between the nuts. Also greased the piston too.
It is a great value bit of kit once you sort the nuts out.
Post #920022 4th Sep 2021 10:20pm
I did a similar thing with water pump pliers to tighten a nut against the end of the cylinder:
 Darren
Post #920026 4th Sep 2021 10:26pm
