![]() | Home > Maintenance & Modifications > Another Puma clutch failure |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3664 ![]() ![]() ![]() |
Luke etc
mine continues to improve with use and where when new I was using a lower gear to increase revs and reduce the judder, I no longer have to, it pulls smoothly in any gear from 1000rpm, the rattling of the transmission at idle is now also much less frequent. changes are smooth and take up great for the record mine had a new Ashcroft output shaft at the same time as the clutch and my gearbox (and engine) only had about 25k easy miles. When it was first fitted I had the idle increased to 1000rpm to try and smooth it out and still have, I really like the slightly higher idle DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
