Home > Puma (Tdci) > 2.4 90 clunk when changing gear
Willfindlay
England 2009 Defender 90 Puma 2.4 PU Arles Blue
When changing gear recently on my landrover, there is much more of a clunk,( you have to be much more careful letting the clutch off,) and when just sat idling in neutral there is a slight rattling noise coming from the drive train. The drive shafts seem ok, and don’t have to much play in and it had a new clutch less than 5000 miles ago, anyone have any ideas? Thanks
Post #917002 14th Aug 2021 8:17pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
the rattle you mention have you checked the gearstick its a common issue to rattle . is you fluid level ok mines a bit clunky in lower gears that's common too Smile
Post #917395 17th Aug 2021 10:04am
Dinnu
Most recent clunking subject discussed on this thread too:
https://www.defender2.net/forum/topic79793.html
About the rattle, do you know what clutch has been put in? I believe some clutches has more or less damping even when in neutral (the gearbox is spinning when in neutral.. just none of the gears is locked to the mainshaft). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #917400 17th Aug 2021 10:21am
AndreB
Netherlands 2010 Defender 90 Puma 2.4 HT Galway Green
Hi, I had exactly the same issue, it appears to be the output shaft. It's a wellknown issue for the puma's as well as the rattling clutch. I brought it in for repair last week after I have been driving it for one year with above sypmtoms, that was not so smart Rolling Eyes
Output shaft and clutch have been replaced for new, now it drives very smoothly without any clunk or rattling.. Had:
Defender 90 TD5 2001 - 225.000 km
Defender 110 TD5 - 2000 - 120.000
Have:
Defender 90 Puma 2.4 2010 - 211.000 km
Instagram: https://www.instagram.com/landrover_diary/
Post #917408 17th Aug 2021 12:03pm
