![]() | Home > Off Topic > What conduit / pipe for putting in trench for future needs |
Landymatt Member Since: 31 Dec 2018 Location: York Posts: 191 ![]() ![]() |
Learned ones,
We've dug a 70m straight trench across the garden for putting armoured electrical cable in. In the future we may want water, other cables for e.g. the internet, cameras etc. at the same place and want to avoid digging again. Does anyone have experience of pulling additional pipes or cables through the corrugated conduit I see advertised for this purpose? I'm also considering using 110mm soil pipe, as that 'feels' like it'd be smoother / easier to pull stuff through. Cheers, Matt |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3564 ![]() ![]() ![]() |
Hi Matt,
You shouldn't really use soil pipe for any cabling, but I have and it works really well as you say it is smooth bore and easy to drag things through ![]() A cheaper option is smooth bore cable ducting. It will be considerably cheaper than 110mm soil and is made for the job. One word of caution, don't underestimate the drag on even a small cable over 70mm. Leave a good draw rope in the pipe / duct and without wishing to sound like the police, you shouldn't be running mains cable and ethernet / CCTV cables (which are not rated for mains use) in the same duct. Over 70m you may also find that if you do run them together, you could get interference on the ethernet / CCTV output. As #1784 says, for how much it costs, sling an MDPE pipe in the trench now. It doesn't need to be in a duct. |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Corrugated pipe will be a nightmare over 70 m. Soil pipe is smooth inside and would work for additional electrical cables. Not certain about water pipe as it is more rigid and tends to bend as it comes off the coil..
Would agree that installing the services now is your safest bet. |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 719 ![]() ![]() ![]() |
I would advise proper electrical ducting, it’s smooth on the inside and has an pull cable built in. I bought a 50m roll a couple months back and it was around £50.
What puddle? Member Since: 25 Oct 2013 Location: Reading Posts: 952 ![]() ![]() |
As a plumber, I would go with 110mm soil pipe, though make sure you go male to female the way you want to future-thread whatever you put through there (so there's no resistance). As Rashers says, leave a good strong rope in there so that you can pull through future stuff...and tie a new rope to whatever you put through in future to leave a new rope in there. Now left.
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 324 ![]() ![]() ![]() |
Whatever you use, feed a piece (or three) of rope through the pipe when you lay it.
Then feed through a plug in the end and tie a knot. Use the rope to pull through when you’re ready |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6127 ![]() ![]() ![]() |
Using cat6STP (shielded) will help considerably when running near mains cables.
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
May be wrong but Mains cable and water pipes shpuld not be in the same duct? Jeff
I don’t think you will find any regulations that say they can’t be in the same duct. Gas pipes have to be segregated for obvious reasons.
Cables are water proof and often installed under water or are installed in ducts which are full of water. There is talk of running Cables through water pipes to get fast broadband to outlying areas (albeit that’s not mains electricity!) Cables don’t actually need to be in ducts. As long as they are armoured, laid in a bed of sand and identified above (usually by tiles or tape) the duct isn’t needed. |
