Home > Off Topic > What conduit / pipe for putting in trench for future needs
Landymatt
Learned ones,
We've dug a 70m straight trench across the garden for putting armoured electrical cable in.
In the future we may want water, other cables for e.g. the internet, cameras etc. at the same place and want to avoid digging again.
Does anyone have experience of pulling additional pipes or cables through the corrugated conduit I see advertised for this purpose? I'm also considering using 110mm soil pipe, as that 'feels' like it'd be smoother / easier to pull stuff through.
Cheers,
Matt
Post #916450 11th Aug 2021 9:45am
#1784
Sweden
My recommendation is to put in a MDPE waterpipe and a Cat6 cable approved for outside already now, the price for those is small in comparison.
Pulling these through a bigger pipe later is possible in theory, but my experience is that it's not so easy in practice.
With electricity, water and ethernet you should be covered for most needs? 110 SE D200 MY21 Tasman blue
Discovery 3 V8 HSE MY06
Discovery 1 V8 ES MY97
RRC 2-door V8 MY83
Post #916452 11th Aug 2021 10:05am
Rashers
Hi Matt,
You shouldn't really use soil pipe for any cabling, but I have and it works really well as you say it is smooth bore and easy to drag things through Laughing
A cheaper option is smooth bore cable ducting. It will be considerably cheaper than 110mm soil and is made for the job.
One word of caution, don't underestimate the drag on even a small cable over 70mm. Leave a good draw rope in the pipe / duct and without wishing to sound like the police, you shouldn't be running mains cable and ethernet / CCTV cables (which are not rated for mains use) in the same duct. Over 70m you may also find that if you do run them together, you could get interference on the ethernet / CCTV output.
As #1784 says, for how much it costs, sling an MDPE pipe in the trench now. It doesn't need to be in a duct.
Post #916454 11th Aug 2021 10:17am
Balvaig
Corrugated pipe will be a nightmare over 70 m. Soil pipe is smooth inside and would work for additional electrical cables. Not certain about water pipe as it is more rigid and tends to bend as it comes off the coil..
Would agree that installing the services now is your safest bet.
Post #916455 11th Aug 2021 10:24am
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
I would advise proper electrical ducting, it’s smooth on the inside and has an pull cable built in. I bought a 50m roll a couple months back and it was around £50.
Post #916463 11th Aug 2021 11:08am
What puddle?
As a plumber, I would go with 110mm soil pipe, though make sure you go male to female the way you want to future-thread whatever you put through there (so there's no resistance). As Rashers says, leave a good strong rope in there so that you can pull through future stuff...and tie a new rope to whatever you put through in future to leave a new rope in there. Now left.
Post #916486 11th Aug 2021 1:39pm
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
Whatever you use, feed a piece (or three) of rope through the pipe when you lay it.
Then feed through a plug in the end and tie a knot.
Use the rope to pull through when you’re ready
Post #916518 11th Aug 2021 6:10pm
Using cat6STP (shielded) will help considerably when running near mains cables.
Post #916566 12th Aug 2021 10:44am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
May be wrong but Mains cable and water pipes shpuld not be in the same duct? Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #916594 12th Aug 2021 4:17pm
Rashers
I don’t think you will find any regulations that say they can’t be in the same duct. Gas pipes have to be segregated for obvious reasons.
Cables are water proof and often installed under water or are installed in ducts which are full of water. There is talk of running Cables through water pipes to get fast broadband to outlying areas (albeit that’s not mains electricity!)
Cables don’t actually need to be in ducts. As long as they are armoured, laid in a bed of sand and identified above (usually by tiles or tape) the duct isn’t needed.
Post #916597 12th Aug 2021 4:35pm
