- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Kubrick1978
I checked the brake fluid - it was fine, but the apps (i have both the new and the old one) still told me my brakes could go at any moment. Suffice to say I turned the car on, moved it about on the drive and voila! Suddenly the apps are reporting that everything is fine again. A bit of a worry but never mind.
I've found the apps sometimes do go a little wrong - e.g. telling me the car is unlocked when it is locked and alarmed etc. Again another worry you don't want if you are parked up in a city centre etc.
PS - when I opened the engine, I noticed one of the caps holding down the panel that needs removing to access the brake fluid was missing - so I've dropped the dealer an email and asked for a replacement cap.
10th Aug 2021 8:37pm |
