![]() | Home > Maintenance & Modifications > Optimill and momo steering wheel fitted - thoughts |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 ![]() ![]() ![]() |
Ditto I bought the same although I went for a 15" Moto-Lita. Great kit.
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1393 ![]() ![]() ![]() |
Ive got the same set up too, but miss the old larger steering wheel. I don't know why, it just felt better to me. Euro-Leafing to infinity and beyond.....
I prefer the thicker grip of the original that’s for sure but most of my motive to change was security so I sacrificed that bit……
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2230 ![]() ![]() ![]() |
The truck originally came with a Momo 360mm 'ish wheel but always felt a little too small, recently swapped out for an OMP 380mm wheel and far better (think the std LR is approx 400mm)
This is a nice compromise and still allows the Optimal lock install ![]() Click image to enlarge |
pilsburypie Member Since: 19 Jul 2021 Location: Birmingham Posts: 176 ![]() ![]() ![]() |
How long did you drive with the old steering wheel before swapping? Maybe you got used to it?
I didn’t drive that long with mine before swapping. |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2539 ![]() ![]() ![]() |
Another thumbs up
![]() Mini Countryman Cooper S Morgan Plus 8 |
Simboii Member Since: 09 Jun 2021 Location: Carmarthen Posts: 71 ![]() ![]() ![]() |
Also got a moto lita steering wheel, although i went 14”, with the optimill QR, thinks its great! |
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 345 ![]() ![]() ![]() |
Is the cap supposed to have an “O” ring fitted as mine is loose. It looks like it should have one? Any ideas? Cheers John |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 167 ![]() ![]() ![]() |
Mine certainly came with a o-ring. It made the difference between ludicrously tight and ludicrously loose.
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 341 ![]() ![]() ![]() |
Yes should have an O ring which makes it hard to push in & even harder to get out!
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17722 ![]() ![]() ![]() |
Yes, should have an O-ring.
A useful mod I did to mine is to drill a small hole radially through the cap just under the flange (between the lower face of the flange and the O-ring) to allow the air which gets trapped underneath when fitting the cap to escape, and similarly the vacuum created when removing the cap to be relieved. With some lube on the O-ring it becomes easy to fit or remove yet remains suitably snug. The hole is invisible when the cap is fitted. Before I had this stroke of modest genius my cap would slowly eject itself a few mm after fitting due to the trapped air pressure and was impossible to keep fully inserted. |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I used the swivel lock dock to store the steering wheel in the house. Mount it on the wall somewhere. Mine lives in the utility room so in the cold weather the wheel is always here arm when I start the journey. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1885 ![]() ![]() |
I used the docking boss to fit the lock into the front part of my cubby box (though admittedly that’s a non-standard and no longer available ‘bare box’ one).
This means I have the swivel lock securely stowed just above/beside the handbrake lever. Couldn’t be more convenient without putting it on top of the dash. Like many things on a Defender there are probably other options/locations that would work for different cars/drivers/configurations. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Piggy501 Member Since: 27 Sep 2017 Location: Scotland Posts: 56 ![]() ![]() ![]() |
I must be doing something wrong as my centre cap falls off freely, especially when removing the wheel. Has anyone else had this happen? |
