Home > Maintenance & Modifications > Optimill and momo steering wheel fitted - thoughts
pilsburypie
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
I’ve fitted the Optimill removable steering wheel kit along with a momo Jet steering wheel and I thought I’d give my opinions. This has clearly been around for a while so my post is hardly ground breaking. But for those considering it might be useful.
Optimill kit:
Rather expensive, but very well made. Looks like machined aluminium. The quick release boss fits so easily. Took me 5 mins to remove the old steering wheel and fit. A word of advice, don’t fit the centre cap that covers the centre nut until you’ve driven your car. I was certain my wheels were straight, but on driving the steering wheel was slightly off. So easy to fix, but a bummer trying to remove the cap.
The swivel lock is also great. Lovely finish and seems to be a decent security measure and visual deterrent. Steering wheel removes and the lock fitted in 10 seconds with a bit of practice. Yo have to line up 3 pins, which sometimes is hard, but a little twist and jiggle sorts.
I made the mistake of purchasing the £25 swivel lock docking station. Also well made but in my naivety I thought this was needed to mount the lock. It’s not. It’s simply a dummy boss to screw inside your cubby box to attach the lock to hold it in place.
Momo Jet steering wheel:
Brilliant. Really pleased. Looks great, however I’d loose the little carbon bits if I could. Feels so comfy and the finish is top notch. The size is also perfect. Slightly smaller than the stock wheel which always felt big to me. It obsures the Rev counter a bit, but Speedo and other dash info is unobscured. Also the smaller wheel gives the steering a little more resistance which I love. Feels perfect and positive. I found the old wheel made me wallow around the road more as the car rocks over bumps…. Kind of like an involuntary reaction. The new wheel has so much less with the increased resistance.
To conclude - Optimill seems well made and a good security upgrade. In turn allows the mounting of aftermarket steering wheels, although you can do so without Optimill. The momo Jet is fantastic. Simple.
Post #915889 7th Aug 2021 9:31am
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
Ditto I bought the same although I went for a 15" Moto-Lita. Great kit.
Post #915893 7th Aug 2021 10:29am
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Ive got the same set up too, but miss the old larger steering wheel. I don't know why, it just felt better to me. Euro-Leafing to infinity and beyond.....
Post #915914 7th Aug 2021 3:30pm
scotty38
I prefer the thicker grip of the original that’s for sure but most of my motive to change was security so I sacrificed that bit……
Post #915915 7th Aug 2021 3:50pm
90 Dreamer
The truck originally came with a Momo 360mm 'ish wheel but always felt a little too small, recently swapped out for an OMP 380mm wheel and far better (think the std LR is approx 400mm)
This is a nice compromise and still allows the Optimal lock install
Post #915966 7th Aug 2021 8:34pm
pilsburypie
How long did you drive with the old steering wheel before swapping? Maybe you got used to it?
I didn’t drive that long with mine before swapping.
Post #915988 8th Aug 2021 3:15am
discomog
Another thumbs up Thumbs Up for the Momo wheel and Optimil swivel lock Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #915989 8th Aug 2021 6:34am
Simboii
Wales 2006 Defender 90 Td5 HT Keswick Green
Also got a moto lita steering wheel, although i went 14”, with the optimill QR, thinks its great!
Post #916026 8th Aug 2021 12:01pm
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
Re: Optimill and momo steering wheel fitted - thoughts
Is the cap supposed to have an “O” ring fitted as mine is loose. It looks like it should have one?
Any ideas?
John
Post #935187 26th Dec 2021 8:15pm
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Mine certainly came with a o-ring. It made the difference between ludicrously tight and ludicrously loose.
Post #935188 26th Dec 2021 8:25pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Yes should have an O ring which makes it hard to push in & even harder to get out!
Post #935195 26th Dec 2021 9:02pm
Yes, should have an O-ring.
A useful mod I did to mine is to drill a small hole radially through the cap just under the flange (between the lower face of the flange and the O-ring) to allow the air which gets trapped underneath when fitting the cap to escape, and similarly the vacuum created when removing the cap to be relieved. With some lube on the O-ring it becomes easy to fit or remove yet remains suitably snug. The hole is invisible when the cap is fitted.
Before I had this stroke of modest genius my cap would slowly eject itself a few mm after fitting due to the trapped air pressure and was impossible to keep fully inserted.
Post #935200 26th Dec 2021 9:35pm
Roy5695
I used the swivel lock dock to store the steering wheel in the house. Mount it on the wall somewhere. Mine lives in the utility room so in the cold weather the wheel is always here arm when I start the journey. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #935207 26th Dec 2021 9:54pm
donmacn
I used the docking boss to fit the lock into the front part of my cubby box (though admittedly that’s a non-standard and no longer available ‘bare box’ one).
This means I have the swivel lock securely stowed just above/beside the handbrake lever. Couldn’t be more convenient without putting it on top of the dash.
Like many things on a Defender there are probably other options/locations that would work for different cars/drivers/configurations. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #935217 26th Dec 2021 11:39pm
Piggy501
Scotland 1996 Defender 90 300 Tdi PU Arrow Red
I must be doing something wrong as my centre cap falls off freely, especially when removing the wheel. Has anyone else had this happen?
Post #935218 26th Dec 2021 11:44pm
