Home > General & Technical (L663) > CB Radio Aerial Mount
Page 2 of 3 <123>
ESU 876
Thanks, Dan,
I think it helps that Ray's T piece is thicker than Thule's. Neatest solution that I've seen.
Neil
Post #947180 27th Mar 2022 1:35pm
DaveCNB
United States
Got one of Ray's mounts
Ray was nice enough to make me a mount to fit a ¾" NMO antenna fitting and ship it out to the US.
Man he does great work, the materials, cuts/bend in the ¼" aluminum and fit and finish are top notch.
Can't wait to get it installed and the antenna mounted/wired up.
Thanks again Ray, you are an artist/craftsman!
Post #947838 2nd Apr 2022 10:41pm
WizzardPrang
Ray's mount looks great, very neat and unobtrusive.
Just wondering, how do you create a ground plane and does the antenna have to be earthed? The roof rails are painted/coated so there won't be metal to metal contact with the mount as far as I can see.
Any advice welcome, thank you. Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #948711 8th Apr 2022 9:46pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I'm using one of Ray's mounts and I basically have the mount fixed to the roof rails and a Sirio Turbo 5000 aerial mounted on Ray's mount, no other earth connections or anything and I have great reception and transmitting. Hope that helps Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #948717 8th Apr 2022 10:21pm
WizzardPrang
Thanks Ian, that's great news. Thumbs Up
Looks like I have some shopping to do. Current vehicle: 2020 Defender 110S
Insta: wizzardprang
Post #948831 9th Apr 2022 10:58pm
WizzardPrang
Thanks to Ray, I now have this:
Fits perfectly.
Also thanks to Hairy Dan for the info. Thumbs Up Current vehicle: 2020 Defender 110S
Insta: wizzardprang
Post #953617 25th May 2022 9:43pm
alabbar
United Arab Emirates
thats grate
Post #967507 13th Oct 2022 5:51am
MattBW
RLD wrote:
yes they fit as long as you tighten them up properly
Hi, anyone know if Ray still makes these? They look fantastic.
Post #971518 17th Nov 2022 11:24pm
Hairy Dan
When you have 3 posts you can PM Ray
https://www.defender2.net/forum/member-rld.html Cheers Ian
Kielder 4x4 Safari
Post #971521 17th Nov 2022 11:52pm
MattBW
Thanks very much, bit of a radio enthusiast and seems the best mount was on this forum. What a lovely find this community is.
Post #971890 21st Nov 2022 12:53pm
PaulM78
England 2016 Defender 110 Other CSW Auto Tamar Blue
Looks a cracking idea, did everyone just run the coax out of the rear door, hinge side then onto the roof?
Post #1013994 5th Nov 2023 10:48am
lightning
lt's great that CB radio is still active in the USA, it's pretty much dead here except for the truck drivers who l think may still use it.
Post #1013999 5th Nov 2023 11:52am
LR Nuts
OTT arial mount.
https://www.ebay.co.uk/itm/176002194673?va...gJM4vD_BwE
OTT price Laughing
Post #1014004 5th Nov 2023 1:22pm
cyberhusky
Luxembourg
I run the cables for 2 antennas along the B pillars on both sides of the Defender inside the car. But that is a bad idea. As rain water is sliding along the cable wetting the rear carpet.
I removed the cables and antennas now and go through the A pillar under the snorckel inside the car vis the grommit seal. 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history)
Post #1014005 5th Nov 2023 2:33pm
WizzardPrang
That's what I've done as it's only for occasional use, e.g. when I'm greenlaning in a group. Current vehicle: 2020 Defender 110S
Insta: wizzardprang
Post #1014013 5th Nov 2023 4:38pm
Page 2 of 3 <123>
