Home > Technical > 19j Engine judder when dropping back to idle
Alan S
United Kingdom 1987 Defender 90 2.5 TD CSW Coniston Green
Hi All,
Have a resent issue with my 2.5TD 19j, When coming of the throttle to idle the engine has now started to judder and almost stall. This have been happening for just over a week. Two days ago noticed fuel filter leaking Diesel. Changed the fuel filled and notice water in the filter. Bled the filter , pump and injectors, still have issue. Idle is 680 rpm.
Any ideas.
Regards Alan
Post #914614 29th Jul 2021 1:27pm
Dinnu
I had the exact issue when my 19J was not getting enough work. I think letting it sit doing nothing in the garage for too long caused something in the fuel pump to stick. I even had occasions that the engine would stall and die. But starts up right away.
Getting off the throttle slowly was my temporary solution. Idling was smooth, hence I ruled out the injectors.
A bit of use solved the issue before I stopped it for restoration. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #914619 29th Jul 2021 2:29pm
