Home > Technical > 19j Engine judder when dropping back to idle |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
I had the exact issue when my 19J was not getting enough work. I think letting it sit doing nothing in the garage for too long caused something in the fuel pump to stick. I even had occasions that the engine would stall and die. But starts up right away.
Getting off the throttle slowly was my temporary solution. Idling was smooth, hence I ruled out the injectors. A bit of use solved the issue before I stopped it for restoration. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
29th Jul 2021 2:29pm |
