Home > In Car Electronics > LR / Alpine Subs
90 Dreamer
LR / Alpine Subs
out of interest , if you were to retro-fit an LR Alpine DH12-18808-BA is the loom adaptor / connector or whatever already in-situ?? and guessing if you have the larger cubby it already has holes for the CA support plate??
or just certain factory models, etc??
if missing what is required for a later Puma XS??
did a search but wasn't sure if you needed Martins loom, etc??
Post #914272 27th Jul 2021 3:31pm
Martin
Site Admin
Only real answer is: check your own vehicle.
My October 2014 build (2015MY) 90 XS didn't have it, but some people on here have reported it in place on lower spec models!
Larger cubby does not have holes ready for the plate, no.
If wiring is missing you need my retrofit loom: https://fnltd.co.uk/shop/defender-alpine-s...-p120.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #914273 27th Jul 2021 3:35pm
90 Dreamer
thanks for that, presumably simply remove the cubby and have a look under the tunnel carpet??
Post #914282 27th Jul 2021 4:02pm
90 Dreamer
Does the loom simply route down the transmission tunnel under the carpet ??
Just wondering how much I need to strip out to install?
Post #915025 1st Aug 2021 4:27pm
Co1
You shouldn’t need to remove the cubby if you have the bulkhead delete. Have a look under it from the back and the loom connector will be there facing the rear. From memory it is orange.
Post #915033 1st Aug 2021 4:56pm
90 Dreamer
No doesn't appear to be anything there, it was more a question of the routing of a new loom??
Post #915047 1st Aug 2021 6:12pm
Martin
Site Admin
My/our new loom has two branches: 1 routes across the tunnel then up to the headunit; another goes down under the seatbox and across to the battery box for power.
The original sub wiring is built into the bulkhead loom and arrives at the sub from the branch which runs underneath the seatbox.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #915144 2nd Aug 2021 12:02pm
90 Dreamer
thanks Martin so probably easiest to strip some of the carpet out to route..........
presumably the power side would handle an extra USB charger added in as need to sort a cubby supply at the same time??
Post #915269 3rd Aug 2021 8:23am
Martin
Site Admin
You should be able to flip up one side (left/UK passenger) of the tunnel carpet.
Yes I could provide a branch for a permanent fed socket Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #915278 3rd Aug 2021 10:01am
90 Dreamer
thank you, how is it best to order??
PM or through your site??
Post #915299 3rd Aug 2021 12:16pm
90 Dreamer
So thanks to Martins loom we now have a fully installed / working LR Sub and have also added some power in the cubby to run a USB port to charge the boys iPod Touch that has been commandeered to provide extra library duties for more moosic......
Post #918207 22nd Aug 2021 6:26pm
