Home > In Car Electronics > LR / Alpine Subs |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
Only real answer is: check your own vehicle.
My October 2014 build (2015MY) 90 XS didn't have it, but some people on here have reported it in place on lower spec models! Larger cubby does not have holes ready for the plate, no. If wiring is missing you need my retrofit loom: https://fnltd.co.uk/shop/defender-alpine-s...-p120.html 1988 90 Td5 NAS soft top 2015 D90 XS SW |
27th Jul 2021 3:35pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2169 |
thanks for that, presumably simply remove the cubby and have a look under the tunnel carpet??
27th Jul 2021 4:02pm |
Does the loom simply route down the transmission tunnel under the carpet ??
Just wondering how much I need to strip out to install? |
1st Aug 2021 4:27pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3683 |
You shouldn’t need to remove the cubby if you have the bulkhead delete. Have a look under it from the back and the loom connector will be there facing the rear. From memory it is orange.
1st Aug 2021 4:56pm |
No doesn't appear to be anything there, it was more a question of the routing of a new loom??
1st Aug 2021 6:12pm |
My/our new loom has two branches: 1 routes across the tunnel then up to the headunit; another goes down under the seatbox and across to the battery box for power.
The original sub wiring is built into the bulkhead loom and arrives at the sub from the branch which runs underneath the seatbox. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
2nd Aug 2021 12:02pm |
thanks Martin so probably easiest to strip some of the carpet out to route..........
presumably the power side would handle an extra USB charger added in as need to sort a cubby supply at the same time?? |
3rd Aug 2021 8:23am |
You should be able to flip up one side (left/UK passenger) of the tunnel carpet.
Yes I could provide a branch for a permanent fed socket 1988 90 Td5 NAS soft top 2015 D90 XS SW |
3rd Aug 2021 10:01am |
thank you, how is it best to order??
PM or through your site?? |
3rd Aug 2021 12:16pm |
So thanks to Martins loom we now have a fully installed / working LR Sub and have also added some power in the cubby to run a USB port to charge the boys iPod Touch that has been commandeered to provide extra library duties for more moosic......
Click image to enlarge |
22nd Aug 2021 6:26pm |
