Home > Td5 > Asientos trasero puma para defender 90 td5
tonyglez88
Spain 1999 Defender 90 Td5 Adventure Yulong White
Hola me gustaria alguien sabe que ha montado asiento trasero de puma a defender 90 td5 el cajon hay que cortar algo? porque yo compre asiento trasera de puma a ver tiene algo idea puede comentar aqui muchas gracias saludos
Post #912426 14th Jul 2021 9:01pm
Hufflepuff
Mr Google says this translates as:
Hello, I would like someone to know that he has mounted the rear seat of puma to defend 90 td5, the drawer, do you have to cut something? because I bought the back seat of puma to see you have something idea can comment here thank you very much
I'm not sure if this means you would like to put a Puma front facing rear seat into the back of a 90 Td5? The rear tubs are difference between the Puma and Td5 Defenders, so I would imagine it would not fit directly.
You can get direct replacement seats, eg. from Exmoor Trim:
https://www.exmoortrim.co.uk/seating/defen...-hand.html
but as you can see, they are expensive. 2005 Td5 90 XS
1989 V8 110 CSW
Post #912429 14th Jul 2021 9:18pm
DSC-off
Post #912434 14th Jul 2021 9:51pm
