Home > Technical > What is this for?
What is this for?
While rummaging about under the RH front seat of my Defender trying to find some reason for my intermittent starting problem, I have found that the wiring doesn't seem to match the workshop manual or electrical wiring/connector manuals appropriate to the VIN! In particular, I have a fuse block that doesn't feature, as far as I can see, in any tech manuals yet appears to original.
Can anyone tell me what it is for? In the first photo below it is outlined by a feeble white-ish circle added to the image. It has four wires entering it, and one huge and one less huge fuse. What do they protect? The fuse block is bolted down to the same fastening as the fog light ECU and it is difficult in situ to see the fuse ratings. It has the appearance of something fitted in the factory since it connects into bound harnesses, and there is no extra electrical equipment (except for things I have fitted myself) on the car - at least, not that I know of!
I cannot match this up to anything in the wiring diagrams or the electrical connector manual, so any advice would be welcome!
Also, underneath the spaghetti is a whitish four-pole connector (visible centre left in the first photo); any idea what this is? I thought it might be the rear door harness but am now not so sure. There is also a single fuse (30A if I remember correctly) in a loose fuse holder under the coils of wire which is the ECM fuse. The black box thingy with the label is the "rear fog guard lamp ECU" (in the old days a switch was enough for one of them)!
My vehicle is an 07-plate 110 DC, County spec, and does not have ABS/TC, aircon, heated seats, nor heated screen, hence only three relays.
First photo: mystery fuse block centre bottom circled, mystery connector left centre.
Second photo: mystery fuse block in top centre, mystery connector bottom right.
Post #86101 25th Aug 2011 3:58pm
K9F
Blackwolf,
Very difficult to determine. Are their any output cables from the fuseblock? Pull the fuse and see if everything is functional? These are the questions that spring to mind....Spotlights.....Winch.....any other auxilliary lighting.....OEM head unit.....are you the first owner....30amp fuse is typical rating for subwoofer....do you have contact with previous owner?
Sorry can't enlighten you! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #86103 25th Aug 2011 4:11pm
I've had a closer look and one is 60A and the other 30A. Both look like factory fit since the wires on the load side run inside the main harness heading out from the seat box, they're not simply taped to it. The feed to the 60A comes from the main BJB input.
The only aftermarket electrical fitting at the moment is the winch, which I fitted, and a 12S socket - it's nothing to do with either. The head is standard and there is no evidence of any extra wiring.
I am not the first owner, and when I bought it it did have an A-bar with two 55W driving lights fitted, but they weren't connected and there is no evidence that they ever had been - no switch, relay, nor wiring.
Very strange! I am reluctant to pull them out to see what stops working, since enough things stop working by themselves without any provocation! It is a Defender after all! I'll check the wire colours since if they are original that should narrow down the circuit.
Post #86114 25th Aug 2011 5:20pm
KPNuts
England 2010 Defender 110 Puma 2.4 USW Alpine White
Don't know what they are, but they are original fit. We have them on our 2010 USW (basic spec + Elec Win + Cent Lock + Alarm battery back up).
Keith 2010 110 Utility Station Wagon
1996 110 Station Wagon
Post #86116 25th Aug 2011 5:31pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
cut them out, you can weigh that copper wire in you know, Whistle
Post #86117 25th Aug 2011 5:33pm
spudfan
Ireland
Fitted to our 2008, no air conditioning or abs/tc.Looks like something that something else plugs into. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #86118 25th Aug 2011 5:34pm
dgardel
Italy
It is dedicated to the engine ECU Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #86150 25th Aug 2011 8:35pm
dgardel
Italy
IID Pro MV License
Post #86151 25th Aug 2011 8:35pm
T1G UP
the covers missing of the fuse box.
when you put the headlights on full beam does it click?
could also be a remap box thing
Post #86156 25th Aug 2011 9:07pm
I took the lid off before taking the photo. No remap - yet.
Mystery thing is definitely a pair of fuses, one 60A and one 30A.
Daniele, there is another 30A fuse in an in-line fuseholder under the loop of wire in the photo which I thought was the ECM. Are you saying all 3 are ECM? One 60A plus two 30A (at least) for the ECM seems a bit much - 1.5kW ?
Post #86159 25th Aug 2011 9:50pm
dgardel
Italy
Remember that the current peak for the injectors is closer to 35 - 40A Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #86172 26th Aug 2011 7:29am
Merlin
Pull the fuse and see what stops!
Merlin
Rolling Eyes
Post #86211 26th Aug 2011 2:34pm
K9F
Merlin wrote:
Pull the fuse and see what stops! Merlin Rolling Eyes
Doh..... Laughing
K9F wrote:
Blackwolf, Pull the fuse and see if everything is functional?
Post #86224 26th Aug 2011 5:57pm
