Home > Technical > What is this for? |
Blackwolf,
Very difficult to determine. Are their any output cables from the fuseblock? Pull the fuse and see if everything is functional? These are the questions that spring to mind....Spotlights.....Winch.....any other auxilliary lighting.....OEM head unit.....are you the first owner....30amp fuse is typical rating for subwoofer....do you have contact with previous owner? Sorry can't enlighten you! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
25th Aug 2011 4:11pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17337 |
I've had a closer look and one is 60A and the other 30A. Both look like factory fit since the wires on the load side run inside the main harness heading out from the seat box, they're not simply taped to it. The feed to the 60A comes from the main BJB input.
The only aftermarket electrical fitting at the moment is the winch, which I fitted, and a 12S socket - it's nothing to do with either. The head is standard and there is no evidence of any extra wiring. I am not the first owner, and when I bought it it did have an A-bar with two 55W driving lights fitted, but they weren't connected and there is no evidence that they ever had been - no switch, relay, nor wiring. Very strange! I am reluctant to pull them out to see what stops working, since enough things stop working by themselves without any provocation! It is a Defender after all! I'll check the wire colours since if they are original that should narrow down the circuit. |
25th Aug 2011 5:20pm |
KPNuts Member Since: 21 Jan 2011 Location: Near Bedford Posts: 45 |
Don't know what they are, but they are original fit. We have them on our 2010 USW (basic spec + Elec Win + Cent Lock + Alarm battery back up).
Keith 2010 110 Utility Station Wagon 1996 110 Station Wagon |
25th Aug 2011 5:31pm |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 |
cut them out, you can weigh that copper wire in you know,
25th Aug 2011 5:33pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4646 |
Fitted to our 2008, no air conditioning or abs/tc.Looks like something that something else plugs into. 1982 88" 2.25 diesel
25th Aug 2011 5:34pm |
It is dedicated to the engine ECU Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
25th Aug 2011 8:35pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
the covers missing of the fuse box.
when you put the headlights on full beam does it click? could also be a remap box thing |
25th Aug 2011 9:07pm |
I took the lid off before taking the photo. No remap - yet.
Mystery thing is definitely a pair of fuses, one 60A and one 30A. Daniele, there is another 30A fuse in an in-line fuseholder under the loop of wire in the photo which I thought was the ECM. Are you saying all 3 are ECM? One 60A plus two 30A (at least) for the ECM seems a bit much - 1.5kW ? |
25th Aug 2011 9:50pm |
Remember that the current peak for the injectors is closer to 35 - 40A Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
26th Aug 2011 7:29am |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
Pull the fuse and see what stops!
Merlin |
26th Aug 2011 2:34pm |
Doh..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th Aug 2011 5:57pm |
