Home > Puma (Tdci) > Puma transmission/prop/UJ/Drivetrain issue |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2637 |
There should be no play at all in the UJs - if there is then they need replacing ASAP. Failure while driving is liable to cause lots of damage.
4th Jul 2021 12:49pm |
KeswickBen Member Since: 28 Oct 2020 Location: Berkshire Posts: 2 |
Cheers, fully aware and my thoughts exactly ref the UJs. So why did the garage give them the all clear?!
4th Jul 2021 1:02pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Some 'specialists' are very much not. Rgds. Chris |
4th Jul 2021 1:09pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5665 |
If the garage you took it to for the service and the diagnostics is the same one. Don’t bother and never return to them. Those UJ’s haven’t been greased for many a mile from what I can see. So they didn’t service it properly, or diagnose it
Even if you just pump some grease in a take it for a quick drive you tend to hear a change in noise and feel. |
4th Jul 2021 1:14pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20294 |
Yep, UJ’s need replacing immediately, wouldn’t recommend you drive it at all either until done.
As mentioned they are dry and haven’t been lubed, and looks to me that there is at least one set of roller bearings in the cup gone there that I can see and the seal gone too. I had very similar, never picked up on MoT either, at least you found it I had a lot of trouble finding it with mine. GKN UJ’s are best, unless you want to spend more and go genuine which are likely to be the same too. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
4th Jul 2021 3:58pm |
