Home > Series Land Rovers > Shroppy's Series 2 |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 |
This week I picked up something rather exciting from West Sussex....
Click image to enlarge More photos to come but she's a 1961, Series 2 109 in military spec having spent its life on Redhill Aerodrome as a fire tender covering only 24k miles. The pump is long gone but the original 'Fire Engineers' badge is still present and the vehicle is remarkably original. The plan is to recommission the brakes and clutch, get it registered with the DVLA and enjoy it as is. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
3rd Jul 2021 9:53am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17450 |
Looks good. I am intrigued to know what it "military spec" about it though, since from the photo I am not seeing any of the expected features.
3rd Jul 2021 10:59am |
Jp, I bought it from a chap called Angus if that joins any dots? It's remarkably unmolested so I'm chuffed! If you're able to fill in any bits of it's history I'd be very grateful.
Blackwolf, it's got an 8 blade fan with dual belts, oil cooler, trussed axle and plated main rails which I was led to believe were military features? 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
3rd Jul 2021 11:10am |
Ah, OK. I am not sure that these are specifically military features, although they are found on many mil spec vehicles of that age (along with other features that I don't see on yours).
I suspect that they are features for a permanent heavy payload (i.e., fitted pump) and upgraded cooling for stationary running, rather than mil. You will probably find them on any specialist conversion of that era with fitted equipment which requires the engine to be running when stationary, such as generators, welders, fire pumps, hydraulic service vehicles, bale elevators, cherry-pickers, and so on. An interesting vehicle, I look forward to seeing more pics. |
3rd Jul 2021 11:27am |
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 377 |
Yes that joins some dots. Angus was a friend of the bloke I knew. I met him a couple of times, seemed like a nice enough guy. I wondered if he/they had sold it elsewhere back then, and it was for sale again now, but it seems it's stayed with him/them until now. I'll drop you a pm. |
3rd Jul 2021 12:37pm |
Some more photos as promised:
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge She runs quite sweetly but has no brakes or clutch so they are the first order of business. Seeing as both the brakes and the clutch operate from the same reservoir I presumed a leak in one of the systems was the cause. So up onto axle stands it goes to inspect. Click image to enlarge To my amazement, the original drums (made June 1961) are still present to all four corners as are the Girling wheel cylinders. Click image to enlarge Click image to enlarge The NSF has two leaky wheel cylinders so hopefully they are the cause of the leak. I've stripped them off to rebuild (hopefully) with a genuine Lucas/Girling seal set. Click image to enlarge I'm going to replace all of the hardlines and flexis to be safe, then attempt to bleed the systems. Whilst under the vehicle I checked for axle numbers and sure enough: Click image to enlarge Click image to enlarge 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
3rd Jul 2021 6:04pm |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 |
Just in case you're not aware that even though it's a shared reservoir the clutch and brake systems are fed from separate sections so in theory a failure in one system doesn't mean a failure in the other.
3rd Jul 2021 6:19pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2169 |
What's the score with the axle numbers?? Does that prove a date of production, etc ??
3rd Jul 2021 6:37pm |
You're quite right Scotty, though in my experience the two chambers have a habit of balancing themselves over time!
As for the axle numbers, they start with 1511 which is the prefix of 1961 109 Series 2. This suggests they are original to the vehicle which is a bonus! 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
3rd Jul 2021 6:42pm |
Well yeah anything can happen and it usually does
Just for completeness 151 is also home market Right Hand Steering too |
3rd Jul 2021 6:47pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7907 |
Lovely!! Enjoy! James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
3rd Jul 2021 8:48pm |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 |
I saw this being transported the other day, probably on the M40. Nice find! 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
3rd Jul 2021 8:53pm |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1381 |
This was my Fire Engine - also a Fire Armour converion, although with a coach built rear body. Fire Armour became part of HCB Angus in the 60's. Mine was also used at Warton Aerodrome by English Electric, later British Aerospace - hence the yellow cab roof.
I wonder if yours looked like this originally? Does it have a PTO for a pump fitted? Click image to enlarge Euro-Leafing to infinity and beyond..... |
6th Jul 2021 7:12pm |
Ah, I can see a PTO knob in this photo - is the pump still there? Nice find, and the Series Two club rally is at the end of this month so not too long to get it running! Euro-Leafing to infinity and beyond..... |
6th Jul 2021 7:17pm |
