Home > Series Land Rovers > Shroppy's Series 2
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Shroppy's Series 2
This week I picked up something rather exciting from West Sussex....
More photos to come but she's a 1961, Series 2 109 in military spec having spent its life on Redhill Aerodrome as a fire tender covering only 24k miles. The pump is long gone but the original 'Fire Engineers' badge is still present and the vehicle is remarkably original.
The plan is to recommission the brakes and clutch, get it registered with the DVLA and enjoy it as is. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #910572 3rd Jul 2021 9:53am
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
I know that car!
A local guy tried to sell it to me on several occasions over the years.
I think he and a mate jointly owned it, or at least that's the impression I got. It was still on the aerodrome when I last saw it, but that was a few years ago now.
Nice little thing, I hope you enjoy it. I was tempted at the time but not enough space and too many projects already on the go.
Post #910577 3rd Jul 2021 10:34am
Looks good. I am intrigued to know what it "military spec" about it though, since from the photo I am not seeing any of the expected features.
Post #910585 3rd Jul 2021 10:59am
Shroppy
Jp, I bought it from a chap called Angus if that joins any dots? It's remarkably unmolested so I'm chuffed! If you're able to fill in any bits of it's history I'd be very grateful.
Blackwolf, it's got an 8 blade fan with dual belts, oil cooler, trussed axle and plated main rails which I was led to believe were military features? 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #910587 3rd Jul 2021 11:10am
Ah, OK. I am not sure that these are specifically military features, although they are found on many mil spec vehicles of that age (along with other features that I don't see on yours).
I suspect that they are features for a permanent heavy payload (i.e., fitted pump) and upgraded cooling for stationary running, rather than mil. You will probably find them on any specialist conversion of that era with fitted equipment which requires the engine to be running when stationary, such as generators, welders, fire pumps, hydraulic service vehicles, bale elevators, cherry-pickers, and so on.
An interesting vehicle, I look forward to seeing more pics. Thumbs Up
Post #910593 3rd Jul 2021 11:27am
jpboost
Yes that joins some dots.
Angus was a friend of the bloke I knew. I met him a couple of times, seemed like a nice enough guy.
I wondered if he/they had sold it elsewhere back then, and it was for sale again now, but it seems it's stayed with him/them until now.
I'll drop you a pm.
Post #910605 3rd Jul 2021 12:37pm
Shroppy
Some more photos as promised:
She runs quite sweetly but has no brakes or clutch so they are the first order of business. Seeing as both the brakes and the clutch operate from the same reservoir I presumed a leak in one of the systems was the cause. So up onto axle stands it goes to inspect.
To my amazement, the original drums (made June 1961) are still present to all four corners as are the Girling wheel cylinders.
The NSF has two leaky wheel cylinders so hopefully they are the cause of the leak. I've stripped them off to rebuild (hopefully) with a genuine Lucas/Girling seal set.
I'm going to replace all of the hardlines and flexis to be safe, then attempt to bleed the systems. Whilst under the vehicle I checked for axle numbers and sure enough:
Series 2 109"
Series 1 80"
Post #910640 3rd Jul 2021 6:04pm
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
Just in case you're not aware that even though it's a shared reservoir the clutch and brake systems are fed from separate sections so in theory a failure in one system doesn't mean a failure in the other.
Post #910645 3rd Jul 2021 6:19pm
90 Dreamer
What's the score with the axle numbers?? Does that prove a date of production, etc ??
Post #910646 3rd Jul 2021 6:37pm
Shroppy
You're quite right Scotty, though in my experience the two chambers have a habit of balancing themselves over time!
As for the axle numbers, they start with 1511 which is the prefix of 1961 109 Series 2. This suggests they are original to the vehicle which is a bonus! 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #910648 3rd Jul 2021 6:42pm
scotty38
Well yeah anything can happen and it usually does Laughing
Just for completeness 151 is also home market Right Hand Steering too Thumbs Up
Post #910650 3rd Jul 2021 6:47pm
JOW240725
Lovely!! Enjoy! James
Instagram @suffolk_rovers
Post #910663 3rd Jul 2021 8:48pm
22900013A
I saw this being transported the other day, probably on the M40. Nice find! 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #910664 3rd Jul 2021 8:53pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
This was my Fire Engine - also a Fire Armour converion, although with a coach built rear body. Fire Armour became part of HCB Angus in the 60's. Mine was also used at Warton Aerodrome by English Electric, later British Aerospace - hence the yellow cab roof.
I wonder if yours looked like this originally? Does it have a PTO for a pump fitted?
 Euro-Leafing to infinity and beyond.....
Post #911049 6th Jul 2021 7:12pm
strang
Shroppy wrote:
Ah, I can see a PTO knob in this photo - is the pump still there? Nice find, and the Series Two club rally is at the end of this month so not too long to get it running! Very Happy Euro-Leafing to infinity and beyond.....
Post #911050 6th Jul 2021 7:17pm
