Home > Puma (Tdci) > To air con or not to air con? |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
I have no pictures at the moment, but could take some once I am home.
Basically: Take the grill off (screws at top and sides). When you look at the condenser you will see a box section bracket around the edge holding it in place. All I did was un-bolt it all, moved the bracket in front of the condenser and then bolt it all back together. Only thing with the lines is that you have to push them back a little so just make sure you don't catch them on anything. Then you are finished. Glyn |
12th Aug 2013 7:49am |
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 |
sounds easy enough. So there was space between condensor and the intercooler that allows the former to be moved backwards. Will a larger intercooler still fit ? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
12th Aug 2013 10:17am |
