Home > Technical > Diff failure caught just in time !
Page 1 of 5 12345>
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
The new to me 130 with 55k on the clock has been making a mechanical rattle between overrun and light acceleration. It appeared to be coming from the front end .
I checked the UJs but they we’re fine, dismantled the hubs and the Cv’s seemed good .
Then thought I may as well have the Diff out to check it over, thinking I can’t possibly have two Pumas with front diff failure within 18 months of each other !
Low and behold the pin holding the whole shooting match together had elongated the holes and had sheered the roll pin . Two teeth had gone but the whole thing could’ve gone bang at any moment.
Here’s a pic or two.
 https://www.instagram.com/hustynminepark/
Post #909079 23rd Jun 2021 12:05pm
Linds Hanson
Potential for catastrophe at motorway speeds!
Post #909084 23rd Jun 2021 1:02pm
jst
thats impressive wear, what are you replacing it with? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #909086 23rd Jun 2021 1:06pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
How does a diff wear like this?
EDIT: A late model 130 with a two pin (one pin) front diff?? Roaming around 🇳🇴🇨🇭
Post #909087 23rd Jun 2021 1:07pm
Retroanaconda
The later diffs must be made of cheese as this never seems to happen on older vehicles.
Post #909095 23rd Jun 2021 1:32pm
Bluericky
Yes , it’s 2009 so I’m not sure that qualifies as late. My 110 was also 2009 that had diff failure AND axle failure (weld sheared)
I’m shopping around for a replacement as I type , nobody has anything ready to go and ideally I’d like to upgrade to a 4 pin diff.
Any recommendations gratefully received https://www.instagram.com/hustynminepark/
Post #909098 23rd Jun 2021 1:42pm
Bluericky
I believe this one failed because the roll pin dislodged (it’s intact in the diff pan ) https://www.instagram.com/hustynminepark/
Post #909100 23rd Jun 2021 1:44pm
jst
2010MY onwards was 4 pin fronts. IIRC Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #909111 23rd Jun 2021 2:28pm
It is well known that the Rover pattern single cross-pin diff cannot cope with the power characteristics of the Puma engine in the longer wheelbase (heavier) vehicles, even Land-Rover acknowledged this when the supposedly started fitting the four-gear diff in the front. It is very evident from this forum that LR did continue fitting the two-gear diff long after they said they had stopped, and it is best to assume that you have one whatever your build sheet shows (you can check by peering through the filler hole of course). Landrover certainly did stop supplying two-gear diffs as replacements for failed units in 110 and 130 vehicles, and in theory you could only buy a four-gear diff if you two-gear diff failed.
The failure mechanism is that the the hole in the diff carrier for the cross-pin elongates, the pin moves, the roll-pin either shears or drops out, followed by the cross-pin, then the pin and gears come adrift and the diff locks solid amongst a catstophic disintegration of gears, teeth, etc. If you are lucky, as I was, all that happens is that the differential action locks up (just as though you have an engaged manual difflock) and the vehicle becomes almost impossible to steer. If you are unlucky the front axle locks up and the vehicle becomes uncontrollable.
Landrover with customary professionalism deny that there is anything remotely resembling a problem. This, despite saying that only four-gear diffs can be used in the front, and despite fitting the four-gear P38 diff in the rear for the whole production run (why? Because the two-gear Rover diff wasn't considered strong enough for the back, but was considered fine for the front! Go figure!)
Post #909114 23rd Jun 2021 2:39pm
Not so, there are many 110 and 130 post this date that have 4-gear diffs according to the build sheet but actually have 2-gear diffs in the axle case.
Post #909115 23rd Jun 2021 2:40pm
Re: Diff failure caught just in time !
You caught that absolutely in the nick of time! Well done!
Post #909116 23rd Jun 2021 2:41pm
Bluericky
I think the moral of the story is that if you have a clatter under very light load (coasting and you casually brush it off as a UJ … check it ASAP
Now where to get a 4 pin diff ?
Ashcroft
Winchester
Xcess
Any others ? https://www.instagram.com/hustynminepark/
Post #909126 23rd Jun 2021 3:19pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
I used Winchester recently for a rear diff. Really good service. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #909152 23rd Jun 2021 6:15pm
Bluericky
Thank you, I tried Winchester and they were making to order, so over a week lead time, then postage
I’d quite like it on the road sooner ! https://www.instagram.com/hustynminepark/
Post #909154 23rd Jun 2021 6:19pm
Co1
Sometimes megasquirt have recons as stock. Try Ashcroft as well.
Post #909162 23rd Jun 2021 6:55pm
Page 1 of 5 12345>
