Home > Off Topic > Apparently it’s Engine Failure
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Evening all,
A colleague of mine has a 2018 2.0 Disco, only covered 33k with full dealer history that developed a loud ticking noise (his words saying it sounds like a tractor) The vehicle is just out of warranty and has been recovered to Jardines Land Rover who without even stripping it say it’s engine failure and the only repair is a replacement.
They are confident LR will contribute under goodwill but have been very conservative explaining the issue.
I know it’s a little vague but does anything like this relate with anyone’s knowledge or experience on here. Do these 2.7’s have known engine issues?
Any suggestions would be welcomed. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #908643 20th Jun 2021 5:47pm
DSC-off
If it's a 3.0 V6 diesel, they're well known for major crank problems, requiring a new engine.
Don't know what the situation is regarding a contribution to the cost.
Post #908644 20th Jun 2021 6:07pm
DSC-off
Our sister site Disco4.com, shows the V6 engine to be very reliable, in comparison to a Puma Defender! Rolling with laughter Bow down
20% of V6 Discoverys have snapped a crank or spun bearings.
48% of Puma Defenders have had a failed intermediate shaft.
https://www.disco4.com/forum/topic154411-105.html
https://www.defender2.net/forum/topic62521-120.html
The repair bill for the Discovery is much higher though....
Post #908672 20th Jun 2021 8:53pm
Leamreject
Morning all, I have corrected the above as this is a 2.0SD4
I’m told they do have a known engine timing chain problem so I need to get more detail on the faults to establish if this could be the failure Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #908711 21st Jun 2021 7:24am
Dinnu
Which manufacturer does not have timing chain issues on ‘modern’ engines. Long gone the days where chains were duplex or triplex. Nowadays the timing chains are more suited for a bicycle than anything else. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #908722 21st Jun 2021 7:44am
