![]() | Home > Puma (Tdci) > Engine/tranmission mounting |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 ![]() ![]() ![]() |
Yes mate mine is the same but like you when I first got mine i thought the same.
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 ![]() ![]() |
Apparently there's not supposed to be any kind of bush or isolator in between. On mine, the two holes don't line up very well anyway.
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
Mines the same, not caused any problems in the last 29k
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Mine is the same.
So, appears to be an unused part or something to keep the piece in place during mounting. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
I think its as described above. There is an optical laser measuring device at the end of the production line. If the two holes line up the test driver
This has been bought on afew sites it should not be boleted to anything. 2.4 90 XS
