Home > Td5 > Air con condensor supplier
benspray
United Kingdom 2006 Defender 130 Td5 HCPU Chawton White
Hi All
Has anyone found anywhere that will supply the aircon rad/condensor for a TD5 Defender on its own without the frame and fan that most places want £400plus for? got to be a cheaper option?
Maybe theres an aftermarket option from an aircon supplier?
Ben
Post #906779 7th Jun 2021 12:18pm
This came up on a thread in the Puma section last week, which uses the same part, and the conclusion was that there really isn't a cheaper option, unfortunately. I think Island 4x4 were the most economic. Darren
Post #906783 7th Jun 2021 12:21pm
benspray
Thanks, I'll take a look, shame as I have 2 frames and 2 fans here now all still ok....
Ben
Post #906785 7th Jun 2021 12:23pm
wyvern
I did a lot of searching last week and can ouly find them sold as a complete unit - there are a couple of overseas sites on Ebay who suggest that there are some condensers which will fit in the frame for the defender, but I am unable to find any confirmation that they will fit .. and there may be ‘issues’ importing from Europe.
So bit the bullet and ordered one from Island 4x4 who were very helpful and its sitting ready for fitting.
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #906846 7th Jun 2021 7:30pm
hank
I looked into this recently and found a handful of potentially suitable cores from other vehicles. I need to remove my condenser to confirm the fitting sizes before I can work out which one(s) are best suited.
The cores I found are for Subaru Impreza/Legacy, Volvo FH-12 and FH-16, Renault Master/Vauxhall Movano, Nissan Patrol and around £60.
Wyvern, can you share links to the items you found? > 110 XS Double Cab
Post #906894 8th Jun 2021 9:05am
Pacha
There are quite a few 'car parts' websites that list ones that they claim to be comparable?
https://www.motor-doctor.co.uk/condenser/l...-5-td5-4x4
https://www.autopartspro.co.uk/land-rover-.../condenser Rgds.
Chris
Post #906923 8th Jun 2021 2:56pm
robk
Netherlands 2002 Defender 110 Td5 SW Epsom Green
Hi Forum,
I am having exactly the same question. The full set (frame, condenser and fan) LR025985 is quite expensive indeed. I only need the condenser, which is not leaking but is missing nearly half the small radiating aluminium bits between the tubing 😀.
The sites that offer the condesers (see above) claim competbility, but the pictures provided are different from what is actually installed in my 2004 Td5.
Does anybody have an update on this search?
BR
Rob
Post #1033659 2nd May 2024 7:57pm
Porny
Site Sponsor
I might be able to throw another option into the mix very soon....
Not going to be cheaper than some of the current options, but is a much more efficient design, using a much more modern core design... and won't start falling apart after 12 months.
Currently undergoing sign off testing.
With single fan or twin fan mounts - and reuses the original frame (and fan if going single).
This is a high quality all aluminium set up.
There has been a few changes to design - photos are original prototype.
 IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #1033665 2nd May 2024 8:55pm
bankz5152
£120 needs a 15" electric fan. Just have to cut your old plug off and refit.
https://www.ebay.co.uk/itm/115948178433?mk...media=COPY
Fits well but needs some.minor bending of the AC lines and a 10mm thick washer in the bottom corners.
Gassed it up a few weeks ago, ice cold better than its ever been! Instagram @defender_ventures
Empire Tuning - Agent
Post #1033746 3rd May 2024 8:40pm
robk
Thanks for the nice pics. Will however the grill fit to the front? The lower part of the condensor sticks out significantly, IMHO the original grill will not fit at the bottom
KR
RK
Post #1035101 18th May 2024 3:55pm
robk
@porny, seems you were able to replace only the condensor while keeping the original frame.
Where did you purchase the condensor (brand model/part no)?
Much appreciated!
KR
RK
Post #1035103 18th May 2024 3:58pm
bankz5152
KR
RK
Well needs an AC grill yeah Instagram @defender_ventures
Post #1035106 18th May 2024 4:10pm
robk
Sure, but looking at my A/C grill, that doesn’t provide enough room for that condenser at the bottom just above the front bumper
Rob
Post #1035123 18th May 2024 7:53pm
bankz5152
Fits fine?
Post #1035125 18th May 2024 8:03pm
robk
Ow, indeed looks like the A/C grill leaves enough room at the bottom for the higher condenser. Great!
@porny, I would still be interested in your route of repairing the (original) condenser. Can you please share the make and model you have used to replace the condenser only.
Best regards
Rob
Post #1035144 19th May 2024 9:22am
