![]() | Home > In Car Electronics > Trailer warning light |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1440 ![]() ![]() ![]() |
All sorted! Another session tonight, my first mistake was that I’d been looking at the wiring diagram for a pre2002 td5
![]() Anyways o/side wheel off and start removing the conduit that houses all the wires. I was expecting something similar to the near side, but they did a good job , that side was a pig to get off, and wires like new, so nothing obvious. I then took the earths off the transfer box nothing noticeable but cleaned up and bolted back on more in hope..... but no change ![]() So then I spent the best part of 2 hours with the multimeter checking the earth wires resistance...... nothing obvious and all low readings. Out of desperation I took the bulb holder off the stop tail on the offside and although not dirty cleaned it and still no change!! So I then tried a new bulb even though the other one worked ....... Sorted ![]() All that for a 50p bulb ![]() Thanks for peoples suggestions. Hopefully this thread will help someone else ![]() |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2231 ![]() ![]() ![]() |
At least its sussed.......
Had a similar thing years ago with a friends car that lit the headlights when the brakes were applied, took ages to sort until we realised that it had previously had a dual filament tail bub replaced with a single filament variant ans was effectively shorting across the holder......took a bit to find ![]() |
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 167 ![]() ![]() ![]() |
My trailer light on the dash has been on since I got my defender, I had a look at a few things then decided I could live with it!
do you mean its on permanent or flashes when the indicators are first initiated??
if its the latter then thats normal only flashing permanently when you connect a trailer plug |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20754 ![]() ![]() |
Glad you found it, it really is a headache I know I’ve been there with similar issues before.
Every new issue can be a surprise, the most odd things can crop up. ![]() ![]() ⛽️🛢️⚙️🧰💪 |
Yep it was a PITA ! You know it’ll either be 10 minute job or several hours, in the end it was both. Worth it though. I think I had 2 issues the frayed wires on the near side coupled with the dodgy bulb. The state of the wires on the near side convinced me it’ll be damage/ wear causing a short/earth issue. When I didn’t find any I was then sure it would be an earth fault. The bulb change was desperation
