Home > Technical > Heater Box - Missing Switch
WhiskyDisco
Thumbs Up Hi all,
I have an ex-Singapore Armed Forces 110 (1986) that I am refurbishing. I am fixing the dashboard binnacle, and seized heater controls and noticed that the hot/cold lever is missing its cable. I traced it to the heater box and find that the switch is missing too!
Have you any ideas about whther this vehicle would have been sold without heat? And how can I get the heater working to handle our terrible British summer weather?
I attach some photos below.
Post #905137 26th May 2021 4:59pm
rallysteve
Looks to be no heater core fitted at all so assume the heater box is there to provide a mounting for the fan and ambient temp air only.
Best bet would be a rusty donor heater box so you can get the hot/cold flap and lever and the air control flap which also looks to be missing. Add a a new heater matrix and heater hoses.
Are the outlets blanked on your engine for the heater hoses or is there a bypass hose fitted?
Post #905138 26th May 2021 5:05pm
WhiskyDisco
Thanks for the reply. I'm not sure how to answer your questions just yet, but I can confirm that there is air flow to the cabin/screen. I take it I would have to drill out the rivets and install the matrix and control, and re-rivet back again.
Post #905149 26th May 2021 5:39pm
donmacn
To install a matrix and flaps, you would need to take the heater apart - the top off at least. It might be easier just to get a good UK spec one if you can find one, and keep the current one somewhere for originality's sake?
I'm not familiar with your older engine (mine's a Tdi) so don't know where you'd look for the coolant pipes to plug in. You might also need to get hold of the spigots that screw into the engine to allow the hoses to fit. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #905165 26th May 2021 6:35pm
Dinnu
I know that Protons in Malaysia only have cold settings. Cold and colder. Not surprising given that it is 32dC all year round in south east asia. So I guess your 110 is a Singapore spec, and they saved a few quids by omitting the heater matrix.
The connection for the hot water from the engine are right at the front, next to the thermostat. Maybe can take a picture of the front part of the engine? Originally there would be 2 short rubber hoses at the front, then 2 metal tubes along the top cover that then connect through 2 small rubber hoses to the heater matrix. Note that 1986 heater matrix have the connection facing downwards. Later heater matrix have the connections horizontal.
Nice looking 110 btw Thumbs Up 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #905170 26th May 2021 6:58pm
Dinnu
Off topic, but I do not think is common on a 110 to have an 88” fuel filler arrangement and a 90 fuel tank as well. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #905173 26th May 2021 7:10pm
WhiskyDisco
The forward fuel filler is a long-range tank, manually switchable from a lever under the driver.
Post #905195 26th May 2021 8:59pm
V8Simon
United Kingdom 1985 Defender 90 V8 Petrol SW Auto Arles Blue
Ignoring the rusty bits, Embarassed this is what it should have (on my old scrap bulkhead pre TDCi)
 1984 90 V8 puma want to be.
Post #905488 28th May 2021 3:41pm
