Home > Td5 > Clutch & Throttle Pedal Mods - done!
Page 3 of 3 <123
Chris90V8
England 1987 Defender 90 2.5 TD XS CSW Portofino Red
Are you not able to click on the link that Excossack kindly posted?
(Couple of replies up ⬆⬆⬆) ðŸšœ. ...... . .... . .. 🚗ðŸšðŸš›ðŸššðŸššðŸš—🚙ðŸš
Post #653354 28th Sep 2017 11:13am
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Yes didn't look up the thread Smile
Post #653367 28th Sep 2017 11:43am
Harry.O
lightning wrote:
geobloke wrote:
To be honest I think if it is motorway driving that is the problem i would install a cruise control system (either the LR simple DIY one or the plug and play units) and be certain of a right foot relaxing drive...
I would love it if somebody could point me in the direction of the "LR simple DIY" cruise control for the Defender TD5.
All l can find is a kit at over £400.
Here's a few links I found a while back. A friend did the wiring in mine based on the links then later I fitted a disco 2 switch mounted to the steering column as the +/set controls to tidy it up a touch. IIRC, the cheap install only works on the later NNN-type ECU, not the early TD5 versions.
http://www.defender2.net/forum/topic2974-15.html
https://www.aulro.com/afvb/technical-chatt...rol-2.html
https://forums.lr4x4.com/topic/80004-td5-cruise-control/
It worked great until I fitted a recon gearbox with a V8 5th gear ratio. Then ECU started reading incorrect revs and knocking the CC off so a speedo correction box was fitted to alter the signals going to the ECU. You would also require this if you have a 1.2 transfer box fitted. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #653436 28th Sep 2017 4:57pm
Coatesyyy
This clutch and throttle pedal mod seem a must, this weekends job! Thumbs Up
Post #654386 2nd Oct 2017 6:01pm
4RF RDS
lightning wrote:
Just look at the picture l posted and the description on my previous post. It's all you need to know.
PS it was the June 2011 edition of LRO. I resurrected this thread from back then!
2011!!! Rolling with laughter never looked at the OP date. Thanks, for posting though. In looking at the time stamp and time difference over here, yours was not yet up when I asked the question. Appreciate the photo (worth a 1000 words as they say)
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #654404 2nd Oct 2017 7:01pm
lightning
Clutch pedal spring modification, definitely do this, so much nicer to drive.
Throttle pedal modification, does make the pedal lighter and well worth trying out. Very easy to return to standard if you prefer the heavier pedal action.
Post #654407 2nd Oct 2017 7:11pm
4RF RDS
Yah, did the clutch thing when I bought it years ago. One of the best mods ever to do to a Defender. Will pull the trottle pedal and have a go at it soon.
Cheers. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #654461 2nd Oct 2017 10:32pm
lightning
You don't need to remove the pedal, you can easily drill the hole with it in place.
Post #654555 3rd Oct 2017 12:23pm
4RF RDS
Excellent I'll give it a go. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #654564 3rd Oct 2017 1:01pm
sherifsalem
Portugal 2005 Defender 90 Td5 ST Java Black
Hi Gents,
Maybe this link helps:
https://thegippo.wordpress.com/2014/10/18/td5-clutch-pedal-mod/
a recommended MOD Happy Travel
www.thegippo.wordpress.com
Post #688431 23rd Feb 2018 3:18pm
Page 3 of 3 <123
