Home > Technical > Radio interference
Scottratt
Radio interference
I have an after market radio fitted to a 2011 90 puma.
I’m getting a lot of radio interference when the engine is on. Would a surpressor rectify this
Post #903685 18th May 2021 8:05am
kmac
Typically radio interference can come from unprotected USB products or even LED products.
If you have any of these try the rubber covered ferrite bead products on the offending items - disconnect all and then connect one by one to find the offending item or items
If you want to be really nerdy you can build and put in a common mode choke.
Shax here tells you how to do it
https://www.defender2.net/forum/topic26844...mode+choke
Post #903702 18th May 2021 10:42am
Scottratt
As far as I’m aware I don’t have any usb or led.
Would a surpressor be any good
Post #903724 18th May 2021 12:11pm
dorsetsmith
Radio interference when the engine is on. sound pitch change when increases you engine RPM Question
Radio interference with old unit you replaced Question
Post #903734 18th May 2021 12:55pm
90 Dreamer
we had an issue with an aftermarket radio years back and after trying various 'fixes' I took the option to remove the radio and found it was simply very poorly connected........
Post #903743 18th May 2021 3:25pm
Scottratt
Yes when engine is on and does increase. I’ve bought it with it fitted so don’t know if it was the sa,e with a different radio
Post #903745 18th May 2021 3:43pm
dorsetsmith
alternator possibly but check your aerial grounding and radio power grounding
Post #903763 18th May 2021 5:43pm
Scottratt
When you say alternator do you mean it’s knackered and needs replaced
Post #903799 18th May 2021 8:03pm
PCM
Can I ask what radio you are having the issues with and what if any aftermarket bits have you installed. Led bumper etc?
Post #903805 18th May 2021 8:30pm
dorsetsmith
No it’s not knackered and no it doesn't needs replaced
Post #903813 18th May 2021 9:10pm
Scottratt
So how could I fix prob,em please
Post #903856 19th May 2021 8:27am
dorsetsmith
You need look at your 1. aerial grounding i.e. remove aerial from the wing and check aerial grounding corrosion
2. radio power grounding i.e. wiring and connectors make shore good sound connection
3. also check aerial coax cable that the screen and mid core are not shorted to the mid core or cores are not open CCT
Post #904038 20th May 2021 8:56am
Scottratt
Thanks
Post #904046 20th May 2021 9:40am
