Home > Maintenance & Modifications > You had one job snorkel...
Page 2 of 2 <12
kenzle8a
Test fit of the intake pipe upgrade, will be matched to a pp cages snorkel at some point.
A few cable ties to hold it on for a test fit
4 inch duct to the air box
102-88mm reduction pipe with smaller 102mm joint from the main hose.
Post #903476 16th May 2021 10:55pm
markb110
Definitely earning your Blue Peter badge……well done Thumbs Up
Post #903540 17th May 2021 1:31pm
westie_
We had the same problem with a puma last year, ended up 3d printing a flange that bolted on to the snorkel. Used pretty much identical hose. Then made a little adaptor to fit the airbox. Sealed the flange up with some neoprene as it did the job.
Cant find any pictures of it and the trucks gone but the cad file is still here, was only learning solidworks at the time so it isn't as 'sexy' as it could be. I've got a mantec puma snorkel I'm doing it for at the moment
 110 Td5 Van
Post #903639 17th May 2021 9:18pm
Tim_Berk
Ukraine 2002 Defender 110 Td5 CSW Santorini Black
Hi. Do you still have files for 3D printing these parts? Can you share it?
Post #1058761 27th Jan 2025 11:14pm
Page 2 of 2 <12
