![]() | Home > Maintenance & Modifications > You had one job snorkel... |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2661 ![]() ![]() ![]() |
Definitely earning your Blue Peter badge……well done
westie_ Member Since: 06 Apr 2021 Location: Warwickshire Posts: 18 ![]() ![]() |
We had the same problem with a puma last year, ended up 3d printing a flange that bolted on to the snorkel. Used pretty much identical hose. Then made a little adaptor to fit the airbox. Sealed the flange up with some neoprene as it did the job.
Cant find any pictures of it and the trucks gone but the cad file is still here, was only learning solidworks at the time so it isn't as 'sexy' as it could be. I've got a mantec puma snorkel I'm doing it for at the moment ![]() Click image to enlarge ![]() Click image to enlarge 110 Td5 Van |
Tim_Berk Member Since: 18 May 2019 Location: Kherson Posts: 1 ![]() ![]() ![]() |
Hi. Do you still have files for 3D printing these parts? Can you share it?
