Home > Td5 > Red light in speedo |
Paulo RB Member Since: 16 Mar 2021 Location: Wirral Island Posts: 11 |
Hi, recently joined and been watching / searching for help, any pointers appreciated.
110 Td5 Heritage, year 2000, owned for 2 months now. sometimes the red light in speedo flickers on, sometimes off, sometimes on constant _ is this connected to factory alarm / immobiliser please? The key fob seems to work intermittently also, could it be a flat battery in fob. ( both fobs do the same. And horn alarm drives me mad) Thanks in advance, Paulo Paul RB |
9th May 2021 6:25pm |
fob battery's CR2032 3V
https://www.defender2.net/forum/topic76517.html?highlight=alarm DO you have volumetric sensor. fitted in side also door pile switches can cores problems Last edited by dorsetsmith on 9th May 2021 7:12pm. Edited 1 time in total |
9th May 2021 6:59pm |
Cheers for that Paul RB
9th May 2021 7:07pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2036 |
Just remember to follow the procedure in your handbook when fob battery changing. Then once battery changed go outside the vehicle with doors closed click the lock button on the fob four times and it will re sync. Then unlock with fob and make sure it is on the same key ring as the ignition key when starting .
Here is the process for fob battery change https://www.defender2.net/forum/post832168.html#832165 Last edited by Ianh on 9th May 2021 7:44pm. Edited 1 time in total |
9th May 2021 7:21pm |
Cheers Paul RB
9th May 2021 7:26pm |
Thanks all for comments, battery changed in remote no drama, all good again, tks. Paul RB
16th May 2021 7:39am |
