Home > Tdi > Transfer box diff fault |
Does the rear prop shaft turn when trying to drive? if yes, then the fault lies with the back axle (diff, half shafts, drive flanges). If no, then it's most likely the transfer box.
Thinking about it a bit more, the fact that the handbrake works suggests that the fault is in the transfer box, too. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
8th May 2021 11:30am |
Tomo44 Member Since: 07 May 2021 Location: Cornwall Posts: 6 |
I thought that but then if the handbreak locks the back axel it proves nothing as the back wheels will be locked if it's the transfer box and the transfer box if it's the rear diff, further investigation has suggested the diff lock isn't engaging, link looks good so changing the transmission fluid to see if any metal appears
8th May 2021 11:41am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5729 |
You drive (without diff lock) your Defender and get a vibration. Then you take the front prop off to check it. But now have no drive to the rear, and non operating diff lock.
This can’t happen. If you have no drive to rear, and non operating centre diff lock you wouldn’t be able to drive the vehicle. |
8th May 2021 12:07pm |
Yes but I didn't know the diff lock wasn't engaging, addressing this problem now
8th May 2021 1:45pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3425 |
The diff lock switch is acting on the locking hub, so assuming that the wiring is good and dash light is also good, the light would come on when it is truly locked.
The diff lock lever is right above the front output flange. Easiest access is through the middle hatch in the seatbox, under the cubby box or middle seat. I am assuming you remove the front prop shaft to isolate the vibration issue. Correct? Propshafts have balancing plates welded to them, and if they fall off, they can vibrate. Check also that the crosses are in good condition. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
8th May 2021 2:01pm |
Prop shafts both have plates both and are sound, still can't get the diff light on, I've checked I have drive to both shafts and I do, sitting still both torq up when power applied, when the rain stops, tomorrow, I shall remove the switch and test it after that I am lost for a solution to the diff lock issue and none the wiser on my vibration issue
Cheers for the help |
8th May 2021 2:09pm |
You’ve removed the front prop, and now the trans box is spinning the easiest route, the front drive flange, as you’ve removed the prop. So no diff or axle problems, just need to sort the diff lock. Take the covers off from inside the defender and expose the top of the trans case and you will see the operation rod. Easy to remove cover and check that grub screw that operates inside shaft is tight and moving shaft. |
8th May 2021 2:14pm |
^^^ IIRC grub screw is only on the high/low shaft.
The cover for the diff lock is the rounded one with 3 bolts. It does not take a gasket as it seals with an O ring. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
8th May 2021 3:12pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8059 |
Just wind out the diff lock switch a few threads, it's stopping the lock engaging. Cheers
8th May 2021 9:50pm |
